Leak around Rear of Transmission-02 WRX 5spd Help Diagnose Pics!
Old Aug 20, 2012 | 02:42 PM
NorCal_Scoob's Avatar
Car Info: 2002 Subaru WRX Wagon
Thanks ahead of the time for any help offered.
These are photos from the underside of my 02 WRX wagon.
It has a fluid leak towards the rear of the tranny, that has seeped down around the crossmember. It hasn't left any fluid on the driveway that I've noticed, it wasn't till i was under the car least week that I caught it.
My initial thoughts were that it was the output seal around the drive shaft, but upon closer inspection that area appears pretty clean...
What are people's thoughts?
By ciatexan at 2012-08-20
If it were the output seal, I assume fluid would be around the base of the DS and that shroud piece shown below.
Old Aug 20, 2012 | 03:29 PM
jdblock's Avatar
Car Info: 2004 STI
Shift linkage input shaft seal. You can see it in the last picture.
Old Aug 20, 2012 | 03:32 PM
Any insight on the difficulty or replacing that, or the urgency to do so?
EDIT: Quick googling and i'm assuming i've got to drop the trans housing... >
Old Aug 20, 2012 | 04:00 PM
xhengmanx's Avatar
Its very common that the rear extension housing leaks. More then likely its that and not the input shaft seal. The extension housing seal is a paper gasket and is a common leak since it starts to deteriorate after high mileage.
Old Aug 20, 2012 | 04:05 PM
Thanks XhengemanX
I just got a quote from the dealer for about 650 to replace... Think i'm just gunna transfer that 650 to my 6spd swap fund and let it roll.
Old Aug 20, 2012 | 04:15 PM
xhengmanx's Avatar
lol yea. Mine is also leaking but i just make sure my gear oil is at full. I drips about 1-2 drops a day if that. If you do decide to fix it, remove your mid pipe, remove your driveshaft, remove about 8 bolts holding the extension housing in place and replace the gasket. its bout 4 hours labor if i remember correctly and whatever the cost for new gaskets are.
syncopation
Mar 3, 2008 12:54 PM
xqwizit
Aug 23, 2007 08:42 PM
STi-owns-evo
Nov 17, 2006 11:39 AM
fastfamilywgn
Apr 30, 2006 09:42 PM
TastyTurbo
Aug 20, 2004 12:38 PM
