HELP! Drivetrain gurus, need diagnosis
Old Oct 1, 2007 | 10:03 PM
robust's Avatar
Car Info: 2000 obs
2.2L 2000 Impreza OBS
The car seems to have something binding when taking tight turns, left or right. Only happens when car is plenty warm, like after my hour long commute to work. It seems, to me the driver, to be coming from the front (there is a noise and a feel, almost as if im driving over bumps, but slows the car like a bind). A friend standing outside can't really tell if it's from the front/middle/rear. But more likely front/middle.
Then, I got the car, warmed up well, on jackstands. I put it into first and let it 'drive' itself, didn't stall out even with no gas, since very little drag i guess. The front left hub would rotate once, make a click then pause, sit for a second, then repeat. The right front would go pretty smoothly. The rears were in sync and were very smooth. (This was apparent no matter what steering angle was.)
This leads me to believe it's the front differential. I saw no leakage from the cv boots up front, and couldn't feel anything weird when feeling all around them.
Is there any way to know exactly? And has anyone replace a front differential and knows what's involved? I would appreciate it alot thanks.
Old Oct 17, 2007 | 11:45 PM
EBTurbo's Avatar
Car Info: 93 EG8
does the car track straight? do you have any pulling to either side when accelerating? decelerating? braking?
EB Turbo
TheRedWRX
May 24, 2008 04:30 PM
Imprezer200
Jul 18, 2006 09:34 PM
neokai
Jul 8, 2005 01:55 PM
Zora
Feb 14, 2004 09:31 PM
mmboost
Jan 9, 2004 11:25 PM
