Need Help/Info on my EJ20T into 98 2.2L Swap
Old Jul 29, 2004 | 07:01 AM
Preza-I's Avatar
Car Info: 1998 Subaru Impreza 2.2l
Question Need Help/Info on my EJ20T into 98 2.2L Swap
I’m buying an EJ20T to put in my 98 2.2L 2 door Impreza
The Whole Engine comes with everything but the Wiring Harness, ECU, and Tranny...
__________________________________________________ ___________
Will I be able to use my existing Wiring Harness, ECU, and Tranny???
If not, where can I find another Wiring Harness and ECU somewhat cheep???
__________________________________________________ ____________
Is there anything else I should know about this type of engine swap before I buy the engine???
I need to know ASAP as time to purchase the engin is running out...
Thanks Guys... : )
Old Jul 29, 2004 | 10:13 AM
kravdra's Avatar
Car Info: '99 Impreza OBS
Don't know if you know this, or if its even a help, but wirings supposed to be the hardest. You can use your existing ECU w/ a turbo controller added, but you won't get optimum performance, and might end up with more problems, using the ECU thats made for it'd be better. Thats about the extent of my knowledge. GL
Old Jul 29, 2004 | 10:48 AM
Preza-I's Avatar
Thanks...
I thinks I'm gonna hold off on swapping to the EJ20T for a while... I think I will just Turbo My EJ22 for now and slowly get all of the correct parts to do a proper EJ20T swap...
Drew1185
Nov 14, 2006 10:14 AM
DesolationSuby
Apr 13, 2006 02:59 PM
TurboPorsche
16
Mar 15, 2006 03:24 PM
My_Red_Suby
22
Oct 26, 2004 10:24 AM
Wingless Wonder
Jan 26, 2004 04:11 PM
