engine swap
Old Sep 5, 2004 | 04:15 AM
go go go's Avatar
Car Info: GF8 ver6
motor will bolt up, wiring might be plugn play if the new motor is 95 or similar.
Old Sep 5, 2004 | 01:32 PM
Kostamojen's Avatar
NASIOC Slut
Make sure to use the 1.8 throttle body, and not to use the knock sensor, and the rest is basically re-pluging things back in and getting the vacume lines to work properly. You might have to fabricate a block off plate or two for the throttle body and IAC, but that depends on the specific 2.2 (the block of plate = just a cut piece of sheet metal in the apropriate shape, no biggie)
Old Sep 8, 2004 | 01:23 AM
Kostamojen's Avatar
NASIOC Slut
I just found out something interesting about the N/A 2.2... If you want, you can get a crank from a 2.5 and it will stroke the 2.2 to a 2.35 with almost a 10 for compression ratio too Good stuff. Should be worth 7-15hp right there.
Old Nov 3, 2006 | 12:38 PM
harrydunn02's Avatar
Car Info: 1997 Impreza Coupe
I just swapped an ej22 in for an ej18 and have been having some problems with erratic idling. I am going to swap the throttle bodies this weekend, since my 2.2s IACV is mounted on the intake manifold-PITA to come off for some reason, maybe theres a bolt i cant find. but anyway, what about the knock sensor? why would you not use it out of curiosity?
Old Feb 2, 2007 | 08:22 PM
alancarb's Avatar
Car Info: 95 impreza
I have a 95 impreza 1.8 that I swapped to a 2.2. I had almost zero problems because the 1.8 intake will bolt right up to the 2.2 so there is no need for harness or ecu swapping.
Also if you want you can buy stock SVX pistons and they fit perfect in the 2.2 and they are much higher compression. I also ported and polished the heads and sent the cams to Schneider racing cams in San Diego and got a 256 duration grind and it runs like a rocket.
All fairly easy to do and cheap. The only problem I found is it knocks and pings at low altitude (I am at 4000feet) and the 1.8 cars didn't have knock sensors
Old Jul 15, 2009 | 09:58 PM
mikise's Avatar
Car Info: Impreza 1997
I want to do the same swap with my 1997 ej18 to a ej22. I know everything fits but I wasn't sure if the ej18 tranny and differentials could Properly handle the engine.
MisterSheep
May 5, 2016 08:11 AM
PacificLegacy
Aug 26, 2014 09:54 PM
joltdudeuc
Oct 2, 2012 09:51 AM
gillz
Aug 21, 2011 10:21 PM
Imprezzive
Mar 28, 2003 09:38 PM
