98 rs to 2000 rs ...need help :(
Old Jul 17, 2009 | 08:56 PM
stirs's Avatar
Car Info: 2000 2 door RS/ daily driver vtech
whats the necesary steps to doing a swap like this?...got the motor and ecu in, all I need is to figure out what cables to cut and muve from the ecu connectors?....any help would be greatfull...thanks in advance
Old Jul 18, 2009 | 12:37 AM
knock's Avatar
Car Info: bici putas
yikes, uh there's going to be a change from maf to map signal, cam position sensor signal, and I'm sure a lot of other little crap.
I have the wiring diagram for the 00rs, but not the 98
Old Jul 19, 2009 | 11:06 PM
stirs's Avatar
i've done all the cables but my check engine light is still on. low input on air injected silinoid? did i miss a cable?
Old Jul 19, 2009 | 11:45 PM
knock's Avatar
yeah, the solenoid isn't getting power or is shorting to ground. The solenoid has a two wire connector (E42) that's after the brown B22 16wire plug.
The ECM pinout is B134.24,
and that goes to B22.7 which in turn goes to E42.1 (righthand side of solenoid plug).
//////this is the ground interrupt that the ecu uses to control the valve
The Main Relay power wire needs to go to B22.1 which feeds to E42.2 (left side of solenoid plug)
//////////this is the power feed and should read over 10 volts
If B134.24 doesn't read under 10 ohms, check your ECM grounds (It should be less than 1 ohm)
If you don't see 10v or more at the solenoid plug, check your relay wiring.
Goodluck maing
Old Jul 20, 2009 | 09:55 AM
tkmotorhead's Avatar
Car Info: 99 impreza 2.5rs
dont forget there is a factory reflash for that fault on a 2000. so if every thing ckecks out???
Old Jul 20, 2009 | 09:57 AM
poo65??
Old Jul 20, 2009 | 11:14 AM
knock's Avatar
my guess is the power line isn't wired in correctly, but otherwise any updates stirs?
Old Jul 20, 2009 | 02:16 PM
stirs's Avatar
knock do you have a diagram?
Old Jul 20, 2009 | 02:24 PM
stirs's Avatar
or were is the relay located?
Old Jul 20, 2009 | 05:28 PM
knock's Avatar
Yeah I have the diagram, in the full factory manual. I pulled that info from the troubleshooting algorithm for the air inject low input cel.
The Main relay is going to be under the dash. But instead of dealing with your relay, check the power line it feeds. That is, check B22.1, the brown 16wire connector that is in the engine bay.
All the solenoid needs is 12v switched power and the connection to the ecu to modulate the signal.
Here's the nug:
Old Jul 20, 2009 | 08:19 PM
stirs's Avatar
ok...ko...I got a red and white wire and the brown one that leads to nothing....I am lost at this point...
Old Jul 21, 2009 | 10:02 AM
knock's Avatar
The Red/White is the power wire and the brown signal wire needs to go back to the ECU (B134.24).
By 'leads to nothing' do you mean it's cut or does it terminate at a connector?
hope this helps
Old Jul 21, 2009 | 10:55 AM
stirs's Avatar
the two cables end up in the motor plug from the firewall. so basically i have to reroute them?
Old Jul 21, 2009 | 11:26 AM
knock's Avatar
Does this mean it's on the car's bulkhead harness or do you mean on the engine harness?
Are you using the original bulkhead plug (brown 16wire) from the 98 or did you cut anything up to use the 00?
These two wires feed the solenoid. If they are coming from the solenoid to the engine side of the brown plug that's a good thing. If the bulkhead side of the plug has no corresponding wires that's a bad thing and you'll need to re-route.
Keeping this simple, all the solenoid needs is 12v power from the main relay (can be spliced into from a number of engine sensors IACV, injectors etc in a pinch) and the ECU signal wire connection.
Old Jul 21, 2009 | 11:40 AM
stirs's Avatar
ecu connector plug are 98 but i made all of them match the 2000. i see what i need to do now let me try it.
maxia001
Jun 1, 2013 04:26 AM
sleepy
Feb 7, 2011 09:56 PM
Stranger
Sep 29, 2004 09:36 PM
domasg
Aug 19, 2004 08:01 AM
domasg
Aug 10, 2004 06:10 PM
