just bought 2.5rs 2000, need help
could someone help me to explain how to change spark plugs on my rs, because when i pull that rubber tube out off engine the spark plug seems to be left inside the tube, therefore i don't know how to pull it out off there...i would greatly appreciate if someone could answer this to me to my e-mail domasg2@netscape.net if not answer on forum is still fine..
You need a 5/8" size spark plug socket. You local parts store will have it. Using a few extentions on the socket and a socket wrench, you simply turn counter clockwise to loosen the spark plug.
When loose, pull it out, and put a new one in the socket, and put that back inside there. I recommend using some thread sealant on the threads. Then put in, and turn clockwise until it stops, now you much ONLY USE SLIGHT FORCE TO TIGHTEN IT... Like, 1/8 to 1/4 turn of the wrench.
Repeat...
also, www.scoobymods.com is your friend
http://www.scoobymods.com/forums/showthread.php?t=3017
Repeat...
Car Info: 98 Impreza RS
yea, the hardest part is finding the right combination of extensions for the wrench. If i remember correctly, the best is a socket wrench that has a slight bend to it (don't know the proper term). Thats what i got to work anyways.
r.l.brown
Cars For Sale
Sep 24, 2004 12:52 PM
