Engine Oil Light on...
Old May 21, 2012 | 04:34 PM
CaliSuby's Avatar
Today as I was leaving work I got the red oil light on .. My oil level is fine... Idle is same .... I reset my battery but it didn't go away... Any ideas?
Old May 21, 2012 | 04:36 PM
GST Motorsports's Avatar
Former Sponsor
Car Info: WRX, EVO, MSP3
Bad sensor perhaps? Or check the single wire that goes to it under the alternator! Something else could be if you've got the OEM pickup and it's failed you could see full oil levels but because it cavitating the pump the idiot sensor is seeing no oil pressure at the high point of the engine.
Old May 21, 2012 | 04:48 PM
CaliSuby's Avatar
I'd like to bring it in to you Friday.... Would it be safe to drive?
Old May 21, 2012 | 05:03 PM
Former Sponsor
I honestly couldn't say, if it's the oil pickup then no it's not safe to drive the only problem is diagnosing that is going to be expensive. I would suggest stealing another sensor from someone else to and see if it's still the same at idle.
huck
Aug 23, 2017 02:18 PM
Racerkid
May 29, 2012 06:16 PM
saab92x
Mar 16, 2009 03:16 AM
06scooby
Oct 15, 2006 10:11 AM
jupiter33458
Jul 24, 2005 03:23 PM
