BAIC: Help! weird noise from engine.
Old Oct 10, 2008 | 08:23 PM
gmodc7's Avatar
Car Info: nothing
ok this started when i bought this 04 accessport and installed it, only to find out that 04 and 05 is not compatable. anyways, the car developed a puffing sound that sounds like an exhaust leak, but not like the leak you get between the dp and cb. everyhitng was recently installed with new oem crush gaskets like 5 days ago with no problems or leaks to speak of. Im running an oem sti up, cobb catless dp and cobb exhaust, and everything was doing well until today. car hit boost. ill start it up again to see if i can locate the sound, but its scary because it doesnt sound like its coming from the dp to cb like it most commonly does. please help if you know whats goin on, ive already listened to the rod knock video and it doesnt sound like that. my car only has 23k on it, this would be ridiculous for it to break already. TIA.
edit: ive isolated the sound to the right front of the car, and it does sound like a exhaust leak. hopefully its just leaking the uppipe gasket. the vitals of the car are stable and even sounds normal at idle. im just super freaked out about it. im gonna try to get a video up in case anyone can diagnose.
edit: video... http://www.youtube.com/watch?v=xL3As0ZHQME
Old Oct 10, 2008 | 09:25 PM
Ivegotthenuts's Avatar
Car Info: 2001 Honda Oddysey
Hey, could I ask what happened when trying to install the 04 AP to your car? What the AP say afterward?
Old Oct 10, 2008 | 09:30 PM
flatline's Avatar
Car Info: Cage and Slicks and Wing OH MY!!
our cars are usually pretty noisey from the factory. what oil are you running.
with the temp changing you might be running to thick of an oil.
i know i was running 10w40 and my car hated it during the winter. i switched to 5w30 and it ran soo much smoother. just a thought
Old Oct 11, 2008 | 02:18 AM
Ballz's Avatar
Do you have a performance turbo inlet silicone pipe too?
Old Oct 11, 2008 | 04:02 AM
willow's Avatar
Car Info: wrx02
Yeah, load up the video. Probably, header to uppipe leak since you did uppipe install not too long ago - like you said.
Old Oct 11, 2008 | 11:27 AM
gmodc7's Avatar
Car Info: nothing
Old Oct 11, 2008 | 12:18 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Tough to say from the video. It could be a gasket pre-turbo, but it also almost sounds like a spun bearing. Lets hope for the gasket
Old Oct 11, 2008 | 12:23 PM
AdamBOMB_STi's Avatar
Car Info: 04.7 AW Time Attack STi
sounds like a blown gasket before the turbo for sure.
Old Oct 11, 2008 | 12:58 PM
gmodc7's Avatar
Car Info: nothing
^thats what i was thinking. we can only pray. i gotta get in touch with speedelement. are they not open today? no ones answering...
Old Oct 11, 2008 | 02:20 PM
GST Motorsports's Avatar
Former Sponsor
Car Info: WRX, EVO, MSP3
That's either the collector to uppipe gasket or one from the cylinder head.
Mike
Old Oct 12, 2008 | 01:48 AM
willow's Avatar
Car Info: wrx02
Given that your engine is young and only exhaust mods - I still stick with header to uppipe gasket. Why don't you just see if they are torqued to proper spec prior to taking to a shop? It's free to inspect it yourself. If that doesn't solve it, you should get another gaskets (both ends of uppipe) and redo the install. Hand torque the both ends 1st, torque the header to uppipe to proper spec 2nd, then uppipe to turbo 3rd.
Old Oct 12, 2008 | 01:57 AM
wrxisthebest's Avatar
y pipe to up pipe gasket...
are u hitting target boost???
an exhaust leak prior to the turbo can lead to low boost..
doublef
Mar 11, 2010 04:14 PM
debelle wrx
Jun 9, 2007 10:26 AM
truWRXtacy
Nov 21, 2005 11:45 AM
Daredevil
Jan 6, 2004 06:43 PM
3RdT
Nov 10, 2003 03:30 PM
