weird noise *help*
Old Jan 5, 2004 | 04:28 PM
Daredevil's Avatar
weird noise *help*
so im drivin home from SF this afternoon
i noticed 1st and 2nd gear sort of rattle a bit but this goes away after drivin a bit
i hvae no problems on the freeway (btw, hi to all those subies who waved at me)
i get home and turn off the car, this noise comes from the engine/underneath me, exactly like knocking/rattling noise
does it only when i turn the car off and on, almost like something is bumping against something, but it seems like it could be worse than that
help me please
no cel's or anything
Old Jan 5, 2004 | 04:32 PM
huck's Avatar
Car Info: 2013 GR STi
Did you check to make sure your exhaust hasn't broken a mounting bracket?
Old Jan 5, 2004 | 04:56 PM
Daredevil's Avatar
ok
so i went to show my mom's b/f the noise
it totally went away... well almost totally, its SLIGHTLY there when it turns off now
everything else sounds normal... cept for now i hear some weird click underneath and ni front of me when i step on the gas
Old Jan 6, 2004 | 02:19 PM
Daredevil's Avatar
help?
seems worse when the car is warm
Old Jan 6, 2004 | 02:54 PM
04blkWRX's Avatar
Car Info: Black WRX, stock
I noticed a click sometimes, it seems to come from the front driver's side wheel well but only when I'm romping on the gas. Unfortunately I have no fixes because I can't make it do it consistently enough to go see a technician.
Old Jan 6, 2004 | 03:23 PM
battousai's Avatar
Check the heatshield where the muffler connects at. Some how my heatshield was all loose and rattling.
Old Jan 6, 2004 | 04:12 PM
ScoobyBoy's Avatar
ditto check the heatshield that thing gets loose sometimes.
Old Jan 6, 2004 | 04:39 PM
Daredevil's Avatar
i don't have any heat shields there
only heat shield i have is the one that covors the turbo
i have helix up and down pipe with apexi n1 catback
no stock exhaust here
Old Jan 6, 2004 | 04:47 PM
Daredevil's Avatar
chaning the oil right now b/c it was below the E
i noticed that heat shield, enxt to the exhaust manifold is just sitting there, not a single screw holding it in place
hopefully this is it
does the engine shake enough to move this thing back and forth?
Old Jan 6, 2004 | 05:57 PM
huck's Avatar
Originally posted by SUP FOOZ
omg your so dumb you didnt check your heatshield? you suck at snowboarding too b*tch :banana: :banana: :banana: :banana: :banana: :banana:
tee-hee.
Old Jan 6, 2004 | 06:43 PM
Daredevil's Avatar
that was the prob
now i need soem bolts to put it back on, but its off until then
btw
have i snowboarded with you?
debelle wrx
Jun 9, 2007 10:26 AM
1hotsuby
Apr 26, 2007 09:55 PM
XkrazyAsianX
Mar 27, 2006 04:51 PM
slow04wrx
Apr 25, 2005 11:21 PM
t3ch9
Mar 28, 2005 05:16 PM
