'02 & '03 ABS issues (and warranty fix)
Old 09-05-2005, 11:29 PM
  #31
blaznasn's Avatar
Originally Posted by subie OCD
I got the letter also, but I wont do it unless Im sure the 'brake ECU' is seperate from engine management. I want to keep my custom ecutek map!
man i want to know also, but no one seems to know, any tuners want to help us out?
blaznasn is offline
Old 09-06-2005, 10:09 AM
  #32
slvrsubywgn's Avatar
Location: EBAIC- Wondering if I should have taken the blue pill...
I'm getting mine fixed in less than an hour. I'll post up and let you guys know what I find out.
slvrsubywgn is offline
Old 09-06-2005, 05:01 PM
  #33
DrD
DrD's Avatar
Car Info: 2012 Legacy 2.5GT-L
also - do you have a completely stock brake system, or do you have SS lines or upgraded pads, etc.?
DrD is offline
Old 09-06-2005, 07:13 PM
  #34
All I have is upgraded brake fluid. I just had a terrible experience down at the shop, posted up in the bay area forum.
Old 10-04-2005, 02:23 PM
  #35
runutsob1's Avatar
reflashed ecu
i have an appt next week to have my abs done along with the other recalls but i need to know if having that replaced is going to screw up my new map settings
runutsob1 is offline
Old 10-07-2005, 01:40 PM
  #36
Sea Dragon Rex's Avatar
Car Info: 02 WRB Wagon (Cobb AccessPort, P7's), 2-73 914 2.0, 74 914-2.0
I'm taking my car in on Monday and will post on Tuesday. I have AccessPort and unfortunately will be taking my car to the same place as slvrsubywagon. It is my understanding that they will be replacing the ABS Control Module and Hydraulic Control Unit (AB-SCM&HU) which is located directly behind the right headlight.
I will be putting my car in Economy Mode so at least the Tech won't be able to have full boost when he is test driving my car. I will also be putting the stock tires and wheels back on the car.
Sea Dragon Rex is offline
Old 10-12-2005, 05:51 PM
  #37
thebankman's Avatar
Car Info: subaru
Just got this done, the brakes actually bite hard when hitting bumps especially downhill, and you can even hear an occasionaly screech as the brakes do their intended job. Completely worth a weekend without the car! Also the dealership didn't say anything about my friend's ECUtek reflashed car when he brought it in, but the whole car is stock anyways except that. And I do not believe the reflash was "deleted" though the battery was unplugged by the dealer for this service.
thebankman is offline
Old 10-12-2005, 06:49 PM
  #38
blaznasn's Avatar
i don't think they would be able to detect the reflash anyways, and unplugging the battery shouldn't erase the reflash. Good to hear it was worth the service though, i still need to get this done.
blaznasn is offline
Old 10-20-2005, 10:37 PM
  #39
DrD
DrD's Avatar
got mine done yesterday - they just replace the ecu - they don't need to remove the valve body, or do anything else to the system - so unless you have a blatant mod to the brake system (4pots or some other big brake kit) you should be fine. Haven't had a chance to test it yet, but I am encouraged by the results which thebankman got.
DrD is offline
Old 10-26-2005, 07:17 AM
  #40
Turbo4Life's Avatar
Tsb Pdf
http://www.northursalia.com/hosting/ABSTSB.pdf
Here's the PDF to the TSB. It even has directions on what they replace.
Turbo4Life is offline
Old 10-26-2005, 09:41 AM
  #41
babylin19's Avatar
Car Info: car
question
They say in that file that its only for the manual tranny....i have a 02 auto and the same thing happens to me when i brake on certain kind of wavey road or bump...so im thinkin im probably assed out on getting this brake ecu swapped for free...what do guys think?
babylin19 is offline
Old 02-23-2006, 07:24 PM
  #42
iNfEk's Avatar
Location: Boostin' troubles away - 4EAT Memories 12.87@103.2
well i'm doing an auto to manual swap but using a complete 03 wireharness and abs controller do you think i have a chance to get this upgrade?
Jon
iNfEk is offline
Old 02-24-2006, 07:41 PM
  #43
Subaru_Kid's Avatar
Car Info: n/a
Why would you want to swap your ABS control unit, are you even sure if it has a problem. Everyone has this retarded image in there head where they think this service is going to improve their braking distance or some other stupid performance fantasy. If your car comes to a stop, then you just answered your own question (it means its good). Let's say it was a rainy day, and you braked really hard and really late, all of a sudden your car started sliding and you know for a fact you didn't feel your abs because there was no brake pedal vibration which is the actuation of the abs solenoid- then it would be a good time to check out that unit if it even is the problem. So unless you have this probem, then don't waste the dealerships time and the techs time or more importently, your time.
Subaru_Kid is offline
Old 07-30-2006, 05:58 PM
  #44
newyorkreload's Avatar
Location: 500mi North of Montana. Enjoying free health care.
Car Info: Bugeyed Autowagon
is this still good? i have 02 that's never been worked on.
newyorkreload is offline
Old 02-22-2007, 06:44 AM
  #45
kungfoochris's Avatar
Car Info: Silver 03 WRX
I am also wondering if I could still take the care in on this item. I purchased an 03 WRX about a week ago and it is completely bone stock and only had one owner. I am unsure if he took it in to have this done.
-- Chris
kungfoochris is offline
horsecut54
03-13-2007 01:32 PM
WRXWagon203
07-05-2004 10:58 PM
RONINMAX
03-20-2004 01:58 PM
ScoobyDoobie
07-03-2003 01:00 AM
jasno999
12-16-2002 05:10 PM
Quick Reply: '02 & '03 ABS issues (and warranty fix)
