Switching 2008 Impreza Wheels (check engine light comes on)
Old Jun 21, 2009 | 05:48 PM
TeamNCT's Avatar
i changed my factory 16 inch wheels for a new set of 17 inch wheels... now this light comes on on my dash board (ive seen this light before one time when i got a flat tire) so im assuming it has something to do with the differance in tire pressure/size... if this is true is there anyway to reset the computer? or am i just crazy and i got a problem with my car the exact second when i changed my wheels? thanks
Old Jun 21, 2009 | 05:53 PM
I_FLY_LOW's Avatar
Car Info: WRB 05 STi+04 Mini Cooper S
it could be tpms tire pressure measuring system a little computer on the rim which communicates with the car now that you switched wheels the computers sends a signal and dose not get one back thats why you got a light i think
Old Jun 21, 2009 | 06:22 PM
TeamNCT's Avatar
well if that is true how do you make it go away? im sure others who have switched rims have had similar problems... thanks alot for your help!
Old Jun 21, 2009 | 06:36 PM
I_FLY_LOW's Avatar
no problem i had the same issue on my mini cooper do you have a button some were in the car with a tire outline and an exclamation mark in the middle?
Old Jun 21, 2009 | 06:49 PM
I_FLY_LOW's Avatar
if you don't have that button then your SOL because from my quick research i did many people say ignore the light or cover it with electrical tape i will keep an eye out for you tho
Old Jun 21, 2009 | 08:58 PM
LegAC_GT's Avatar
Car Info: 05 OBP LGT LTD. Sedan
i did the same with mine. You cant really do much other then pay for the actual tire monitoring sensors or switch them from your stock wheels to your new wheels. Until you do so the light will stay on. I am currently just rolling around with the light on because i make sure my tire pressure is correct. should be 33 fronts and 32 rears if you are a sedan i think, double check in your owners manual.
Old Jun 22, 2009 | 03:38 AM
TeamNCT's Avatar
do you know what the sensors look like on the wheels? i didnt notice anything...
Old Jun 22, 2009 | 03:41 AM
LegAC_GT's Avatar
http://www.tirerack.com/tires/tirete...hid=44#sensors
check there as it display for each type of make. Subarus should be red and pretty small. :-)
Old Jul 6, 2009 | 01:35 PM
WREXNFX's Avatar
Car Info: 05 WRX Wagon and 08 Civic Si
the sensor is inside the wheel most mfg attach it to the valve stem on the inside of the wheel if you did not swap them to the new wheels then the light can not be reset.
there should be more info on the system in your owners manual
Racerkid
May 29, 2012 06:16 PM
saab92x
Mar 16, 2009 03:16 AM
06scooby
Oct 15, 2006 10:11 AM
cmlnr
Jul 20, 2004 05:38 PM
rash
May 17, 2003 12:32 PM
