Suspension Noice - help!
Old Dec 11, 2002 | 04:18 PM
ImprezaRSDriver's Avatar
hrmmm, I have the Prodrive setup which is very similar to yours with the exception of the springs and I have not had any clunking noises at all from the rear. Did you put on the rubber pad that is supposed to go at the bottom of the struts where the spring perches on?
The only noises that I notice are my jack and tool kit moving. An idea could be that the board that is right above the spare could be moving around. At least that is what I had and then I got a mat to hold it down and problem solved.
Old Dec 16, 2002 | 09:20 AM
mayonaise's Avatar
Sounds like the spring isn't set properly.
Nick C.
wrx 03i
Jan 10, 2011 04:27 AM
saltysti
Jul 11, 2009 09:04 PM
butter2000
Mar 23, 2005 11:10 AM
190hpkilla
Aug 31, 2004 04:10 PM
dropkick_muppet
18
Jun 20, 2003 02:51 PM
