Steering Rack Bushings Problem
Old Jul 16, 2007 | 10:02 AM
OneManArmy's Avatar
General Pimpin'
Originally Posted by ipozestu
You can make a tool very easily. Get like a 1" socket, a long hex bolt, a washer and a nut, feed the bolt through the socket, through the bushing, and put the nut on the other side. Start cranking on the bolt and the bushing will pull itself right into the socket. Repeat. I did mine this way a couple of years ago. Actually, I sent whiteline an e-mail about this and bammo; they started putting them in the kit. I'm not going to take credit, but I think I had something to do with it.
take the credit.....
I spent time under cars doing those damn things 3 times. Tool would have helped. Leave it to an engineer to think about this kind of ****.
Old Jul 18, 2007 | 08:39 PM
NorCalDC5's Avatar
Car Info: 2016 FXT
Second best mod i've done next to my sways. (suspension wise)
I just installed them and I don't feel a difference!
Old Jul 18, 2007 | 09:21 PM
WRXakaBooSTi's Avatar
Car Info: Subaru?
wouldnt be surprise if i dont feel a difference. i havent installed mine yet. bushing seems so thin anyways... cant really get any harder.
Old Jul 19, 2007 | 09:38 AM
OneManArmy's Avatar
General Pimpin'
Honestly....I think these people that rave about how huge a difference it made either had VERY worn bushings or are full of crap. Kind of like a butt dyno.
It's worth it just cause it's cheap. Its worth it if you have mad miles on your car. But I wouldn't expect much out of it.
When your really pushing it you'll notice it a bit. It helps the steering a bit when your up at that 8-9/10ths driving. Little more feeling in the wheel and a little more precise. Not some miracle mod by any means in my opinion.
Old Jul 19, 2007 | 10:29 AM
03_Impreza_Al's Avatar
It may not be a miracle mod but I like how it changed the steering into a more sporty feeling. A mod I definitely would recommend if you like those subtle changes.
Old Jul 19, 2007 | 10:32 AM
Try taking your car on a off or on ramp. I noticed a difference =\
Old Jul 19, 2007 | 05:53 PM
NorCalDC5's Avatar
Car Info: 2016 FXT
I think I didn't notice as much as you cause your car is an 03 and the 05 and up models have a different steering rack
Old Jul 19, 2007 | 06:58 PM
BugeyeREX02's Avatar
Car Info: 2002 WRX
Rack bushings
I have found it really easy to do if you loosen the pinch bolt on the shaft to pinion. Let it slide down about a half an inch, but not all the way off... Make sure you mark the two pieces before you loosen the bolt or you may be in for some crooked steering wheel action!
Old Jul 19, 2007 | 11:33 PM
Probably...
Old Jul 20, 2007 | 07:34 AM
ipozestu's Avatar
Car Info: Broken Subarus
You can feel it, partiularly in quick transitions, and heavy steering input. It also seems to hold a line in mid corner, much better
Old Aug 5, 2007 | 02:05 AM
leari3fei29ud4's Avatar
banned
my whiteline kit didn't come w/ the grease packet. will any multipurpose grease suffice?
Old Aug 5, 2007 | 11:43 PM
ipozestu's Avatar
Get some lithium grease
Old Aug 6, 2007 | 09:17 AM
banned
awesome. thanks
chochocho
Nov 18, 2014 09:17 PM
48mpg
Sep 19, 2004 02:32 PM
DJ Catchem
Jun 6, 2004 06:41 PM
Mach5WRX
34
Feb 19, 2004 06:27 AM
mellowwrx54
May 27, 2003 06:28 PM
