rs to wrx brake swap question
Old Jan 4, 2004 | 10:22 AM
EtchyLives's Avatar
The RS to WRX swap is a straight bolt-on. You just need calipers, pads, and discs. You can find used WRX front brake kits from people who have upgraded for pretty cheap. I sold mine with extra pads for $200. I don't have anymore, sorry.
Old Jan 4, 2004 | 11:02 AM
Uncle Scotty's Avatar
For all the info on the RS--->WRX and 'H6' brake swap see:
http://www.scoobymods.com/forums/sho...hp?threadid=22
And:
http://www.scoobymods.com/forums/sho...p?threadid=814
Piece of cake
Old Jan 4, 2004 | 04:41 PM
DDMan's Avatar
Car Info: 2002 Impreza 2.5 RS Midnight Black Pearl
Not 100% sure of my measurements, but I think its like 10.6in Vs 11.2in or something like that (again, not 100% sure, but the WRX rotors are about .5" larger in diam.) Not sure of the rear H6 vs stock rear diam.
As for the brake swap heres the whole deal:
98-01RS / 02WRX: Uses old style calipers, and brake pads.
02+RS / 03+WRX: Uses NEW style calipers and pads.
the two types are NOT COMPATABLE (as in you cant take an 03WRX caliper and bolt it up to an 02 WRX caliper bracket)
other than that...you should be fine. The WRX rotors are the same for all years, so you can get any year WRX rotor. Good luck, and hope it works out for ya!
Old Jan 4, 2004 | 07:40 PM
Peaty's Avatar
some info on that here:
http://www.scoobymods.com/forums/sho...=&threadid=454
Old Jan 4, 2004 | 07:53 PM
Peaty's Avatar
Just a minor point all Legacy's from 2000 on use the same rear rotors not just the ones with the H6
Old Jan 6, 2004 | 10:09 AM
Peaty's Avatar
yes they will fit
Old Jan 6, 2004 | 05:05 PM
Originally posted by Peaty
yes they will fit
Old Jan 6, 2004 | 08:28 PM
Peaty's Avatar
Originally posted by mr. m
i assume this will work with wrx rears instead of the outbacks?
WRX and RS rear rotors are the same size AFAIK so I guess the answer to your question is yes
Old Jan 7, 2004 | 06:35 AM
Peaty's Avatar
Arrow
Have a look here:
http://www.subaruwrxparts.com/tuneup.html
Notice the same part is used on the RS and WRX for the rear brake rotor
Peaty
PacificLegacy
Aug 26, 2014 09:54 PM
ch0g
Aug 27, 2006 06:14 PM
kansai_wrx
Jun 27, 2006 12:28 AM
ThisizBrian
Jun 11, 2006 08:48 PM
DDMan
Jul 28, 2003 10:49 PM
