RPM, fuel injector pulse
Old 03-19-2007, 12:23 PM
scarface's Avatar
Car Info: 2005 WRX STI
hey guys!!
Just got a HKS Camp system for my sti. Installed it and got the Speedometer function to work in it. But for some reason the RPM signal wont work and the fuel monitor wont work either. So I did a lot of research on this before i even installed it and I already have a printout of all the ecu pinouts.
Speedometer = Vehicle speed signal This works!
RPM = Engine speed output This does not work
Fuel injector monitor = Fuel pump control unit This does not work
Does anybody know the exact pin that the rpm needs to be connected to? Because there is also an acceleration pedal control sensor. So im not sure which one this needs to be connected to. any of you guys that have had a successful tach install could be of some help here.
And finally the fuel injector monitor. It calls for an injector pulse signal. Now i assumed that the fuel pump control unit signal # 1 would be the right pin for this because it is a waveform. So once again if anybody has had a successful install on a fuel injection monitoring system please help.
Thanks guys.
Eli
scarface is offline
Old 03-19-2007, 02:34 PM
scarface's Avatar
Anybody have any info???
Nobody has done a tach install?
Bump for info
scarface is offline
Old 03-19-2007, 03:49 PM
scarface's Avatar
bump for help
scarface is offline
the_truth
05-31-2013 09:24 AM
castro
08-15-2009 04:26 PM
Bagin,DVS
03-25-2008 10:22 AM
2point5AWD
07-01-2006 07:19 PM
Checkpoint
10-15-2005 08:43 AM
Quick Reply: RPM, fuel injector pulse
