rotors stuck - how do I remove them? (was: Rotor help)
Old Sep 2, 2006 | 12:45 PM
nhayden's Avatar
Car Info: 2004 Impreza 2.5TS
Rotor help
I am trying to change out my rotors and can not get the OE ones off.
Am I missing something? I thought that once you pull the lug nuts, wheel and caliper, the rotor should just pop off. I even smacked it a few times with a hammer and a block of wood, not even a little budge.
My car is 3 years old with about 45K miles. It has seen it's share of salted winter roads. I was thinking that the rotor is just rusted on but once a hammer couldn't get it loose, I feel that there is a pin or something that I am missing.
There is the large nut in the center but I am pretty sure that is part of the front drive shaft.
Any help or suggestions would be greatly appreciated.
Old Sep 3, 2006 | 06:08 PM
chris1122's Avatar
once you removed the caliper, there is nothing hold the rotor, I just changed my 02wrx front rotor recenlty, I use W-40 spray around the bolt, and hit it back with plastic hammer and came out, nothing relative with center nut.
Old Sep 3, 2006 | 06:30 PM
lovesmysuby04's Avatar
Car Info: 06 STI WRB/Gold
There is two bolt holes on the rotors. Thread them with the right size bolt, I forgot the size, and do it evenly. The rotor should pop off. Make sure when doing the rears you leave the parking brake off because it will hold the rotor on there too.
Old Sep 4, 2006 | 10:02 AM
Wingless Wonder's Avatar
Rotor removal. So simple and effortless with a couple of bucks worth of the correct size capscrews. Save 'em in your toolbox for any Subaru rotor removal job.
Old Sep 8, 2006 | 06:07 PM
lightning_wrx's Avatar
Car Info: 2002 Subaru WRX
8x1.5x2.5 is the thread size for the two bolt holes
nhayden
Jul 1, 2006 08:45 AM
Z06-KILLR
Dec 24, 2003 11:01 PM
SubySal
Dec 3, 2003 08:22 PM
Speed FX
Dec 7, 2002 03:07 PM
