Rear sway bar to help tire rub?
Old Feb 24, 2010 | 03:23 PM
nolan's Avatar
Car Info: 02 MBP wagon
I got an 02 wagon sitting on JDM pink struts. Fairly low, but rides well. Wheels are 17x8, forgot the tire size..
On hard turns, my rear tires barely scrape the inner fender well. It hasn't cut my tires yet, but I imagine it would eventually. I have stock sways, and I was wondering if an aftermarket rear swaybar and endlinks would prevent the rub? 22mm, 24mm?
Don't necessarily want to roll the fenders..
any thoughts?
thanks.
Old Feb 24, 2010 | 03:34 PM
silverbullet415's Avatar
how wide are the tires tho
Old Feb 24, 2010 | 03:51 PM
nolan's Avatar
Remember now:
225/45/R17 tires.
The fender isnt rubbing the top of the tire, but rather the sidewall, so I believe if I can eliminate unnecessary shock travel on hard turns, I can eliminate the rub?
Old Feb 25, 2010 | 09:01 PM
Wally's World's Avatar
Car Info: Java Black 04' STI
Just for the performance advantage I would get sway bars. Although rolling your fenders should definately work and be less expensive. I'm surprised you're rubbing w/225's, must be your rim offset. Sway bar's should take enough of the lean out while hard cornering to help the situation.
Old Feb 26, 2010 | 03:18 PM
nolan's Avatar
How will only doing the rear sway affect overall handling? Is it wise to do F + R at the same time? Reasons? Evidence?
Old Mar 5, 2010 | 03:44 PM
owencalouro's Avatar
Car Info: 2005 wrx
i have 235 and a sedan (wider fenders then your wagon) on swift springs, and i was rubbing with and without sways bars, they didn't seem to help at all. Just go get your fender rolled its worth it. Also i am running just a rear whiteline bar and its awesome, helps out a lot with under steer.
Old Mar 5, 2010 | 09:34 PM
nolan's Avatar
Yea I was thinking about going rear sway only. If I were to have my rear fenders rolled, where would I go? Or should I rent a roller and google it..?
Old Mar 16, 2010 | 04:08 AM
darkonion's Avatar
Chicks dig me. April Fool's!
any thoughts?
thanks.
Sway bars probably won't help you in this situation. Raise your car, or get your fenders rolled or pulled...
By increasing your rear sway bar size, you'll be making your car more easy to rotate, or come out in the rear. As for your second question. It depends. Suspension is tricky. Not all cars are the same. Not all drivers are the same. Personally, change one thing at a time, and then figure where you want to go from there. If you are changing your rear sway bar, might as well upgrade endlinks and bushings as well.
As far as I know, there are 3 places that offer fender rolling services. LIC Motorsports in Novato, Auto-HQ in Redwood City, and Mach III in San Bruno(?). Something like that.
Old Jun 10, 2010 | 03:54 PM
nolan's Avatar
Thanks for all the info.
Conclusion:
So as far as handling characteristics, the RSB made a world of difference. As expected, however, it did not completely eliminate the rub.
Fenders are getting rolled soon. Overall, for daily drivability, I couldnt be happier with my setup (Sti struts, tien springs, and perrin RSB 22mm)
Eventually, I'll swap springs, but that is how I bought them..
flatline
Jan 21, 2007 04:49 PM
jc0019
Oct 7, 2005 07:53 PM
02eugeneRS
Mar 13, 2004 05:57 PM
GottaREX
Feb 25, 2004 09:37 AM
