need some brake advice..
Old May 11, 2006 | 02:10 PM
subiescottwrx's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...tem=8064796122
are these worth a damn? and is it a full set? 2 for front and 2 for back?
thanks..
im replacing my 02 stock wrx pads........i dont do much crazy with my vehicle, just street use mainly.
Old May 11, 2006 | 02:29 PM
platypus's Avatar
Car Info: dangerous with a wrench
Lots of folks have used axxis ultimates, and I've heard good things about them (although I haven't used them myself).
As far as it being a full set, you'd be better off asking the seller.
What don't you like about your current braking setup, and what are you running right now?
Old May 11, 2006 | 07:17 PM
my stock pads are simply worn out.....just need some cheap but good brake pads.
Old May 14, 2006 | 04:14 AM
Ok i found some axxis ultimates online, good prices like 100 bucks for front and rear......
I'm guessing that most likely i do not have to replace the disc, and that these pads will be compatable with my stock disc?
Old May 14, 2006 | 04:45 AM
I found this page
http://www.zeckhausen.com/Subaru/WRX.htm
scroll down to the brake pads...im thinking about the deluxe axxis...
anyone have trouble with this vendor? these pads should be ok for an 02 right?
Old May 14, 2006 | 11:34 AM
Keisatsu's Avatar
Car Info: Broken ass stock '02 WRX
another question would be how do you drive, aggressive? If so I'd recommend a pad with a higher temp rating than the Deluxe (they are about the same as OEM pads if memory serves me correctly)
If you just cruise in your subbie, I'd go with the deluxe
Old May 14, 2006 | 02:06 PM
thanks for the resonse, i basically just drive to get around, the dc area really sucks for traffice....i dont drive aggressively......maybe on some back roads, but thats rare..
Old May 23, 2006 | 02:09 AM
ok folks one more dumb question
i bought :
63-213-0721
63-213-0770
both of these are front and back Axxis deluxe pads...
my dumb question is:
is there only ONE pad per box or a pair? ....
thx
Old May 23, 2006 | 05:54 PM
Toiletbrush's Avatar
Car Info: '94 WRX, '97 Forester S/Tb, '95 WRX-RA
There should be 2 sets per box (4 pair total). Both sides for the front and rear. If you DO get one pad per box, its time to leave that negative feedback!
Old May 23, 2006 | 10:19 PM
thanks buddy, i feel much better
snowflow
Feb 15, 2009 08:30 AM
subie OCD
18
Nov 22, 2005 02:52 PM
Fatty McBastard
May 9, 2005 06:21 PM
Slack
Apr 18, 2005 04:29 PM
