need help with Sway bars and equipment.
Old Feb 16, 2003 | 02:44 PM
jasno999's Avatar
Car Info: Blaze yellow WRX 2002
Ok I need to know what equipment will work with what sway bar. Say I want to get a whiteline rear adj. bar or a MRT adj bar. What kind of end links do I need to get and what size and type of heavy duty mounts do I need?
I see there are different sizes like the whitline bar is a 22mm bar that is adj from 20mm to 24mm. So do I get a heavy duty mount that fits a 24mm bar of a 22mm bar???
And doe the end links fit any size bar or are they determined by size too????
Help me. Please
Old Feb 17, 2003 | 12:05 PM
jasno999's Avatar
Do you rememebr the overall price for everything?
Old Feb 17, 2003 | 02:19 PM
jjunior887's Avatar
Car Info: 22
allsubaru.com has the rear bar 4 $119 plus shipping, seems like the best price i could find. As for the endlinks, I think a few people have broken the whiteline ones during autoX so you might want to spring the extra few bucks for the Kartboy ones(usually $100 shipped from most places)If you look at the 2 pieces you will see why the KB's cost more. As for the mounts they have them at allsubaru for $65. You could also get the perrin adjustable bar and mounts for around $185 or so from nino in the vendors forum. -James
Old Feb 19, 2003 | 11:47 PM
All the aftermarket bars should work with stock hardware, and the aftermarket hardware should work with stock bars... so pretty much mix and match as you see fit.
Old Feb 21, 2003 | 12:11 PM
jasno999's Avatar
sweet. So you guys think a 22mm bar makes a big difference on the back?
Old Feb 21, 2003 | 03:52 PM
Yes, you should notice your car being more willing to rotate through a turn. It's not as big a difference as in an old style RS though, since those came with puny little weak sway bars. Yours isn't nearly so wimpy.
TylerSTI
Nov 20, 2007 10:51 AM
hayakunai
Oct 10, 2006 03:12 PM
paultg
New England
May 31, 2003 07:37 PM
Imprezer
May 8, 2003 05:12 PM
