lowering my car?
Old Mar 13, 2004 | 05:58 PM
Flash N Dash's Avatar
Car Info: WR Blue WRX
Perrin puts out a nice spring that would lower your car to a great height for your set up.
Let me know if you are interested in this or any spring kit and I will try and help you out!
Thanks,
Brian
Flash N Dash Performance
Old Mar 13, 2004 | 10:46 PM
Uncle Scotty's Avatar
I'd use the Eibachs before I'd use the Tiens or Perrins...
Old Mar 13, 2004 | 10:59 PM
MO REX's Avatar
Car Info: 02 PSM WRX
I agree Im happy with my Eibachs.
Old Mar 14, 2004 | 12:01 PM
daybreak's Avatar
Car Info: MBP is the blackest of blacks. HOLLA BLACK!
Third for Eibachs. I'm happy w/my Eibachs.
TEINs - i hear the ride is crappy and harsh, and they will blow the stock struts easily.
Old Mar 23, 2004 | 12:56 AM
caterpill's Avatar
Car Info: Rust bucketo
Well really, it's up to your taste. A spring that drops the car low like Tein can't really be plush as a spring that doesn't. A spring that lowers a lot more then another has to be stiff, or else you would be bottoming out too often. If you had a soft spring that dropped 2", you would probably hit your bumpstops often, giving you one hell of a jolt each time.
Also, it is because of this stiffness that your stock shocks will wear out a lot faster. It's a common request to be low and ride comfortably... But it's not really that easy to get with just springs. Coilover systems can be more comfortable while being low because of their adjustable dampening and 2-way height adjustment; more travel allows for more spring/body compression, and they can use a softer spring too.
And .. it also depends on what you prefer. There isn't really an "optimal" setup, except what you like. For some reason, people misrepresent a spring with a stiff ride as being "crappy" but it's not.. it's just stiff ...
Old Mar 23, 2004 | 01:09 AM
de pilipino guy's Avatar
Car Info: none
agree with caterpill
i have tein s-tech springs and i like them(so far)
Old Mar 23, 2004 | 02:17 PM
silver satin's Avatar
I had Tein's and they were perfect not to harsh got rid of uneven wheel gap price was right.. Had Eibach now on two cars neither of which I purchased and sorry maybe it is the cars but the ride on both cars was/is bouncy and harsh maybe just me and the cars. But everybody has different taste's. If somebody local gets some Eibach's and throws them in and I can take it for a spin and like them then I might get them...
Racecomp Engineering
May 22, 2008 08:54 AM
LittleBlueWagon
18
Apr 19, 2008 07:07 PM
2point5AWD
Jan 13, 2005 08:20 AM
bluebiker
Nov 24, 2003 06:15 PM
wizardWRX
Jan 20, 2003 10:07 PM
