Knocking sound coming from rear left wheel
Old Jun 7, 2008 | 06:18 PM
sypher66's Avatar
Car Info: 2006 STI
Question Knocking sound coming from rear left wheel
I have a 2006 STI and have had a knocking sound coming from the rear left wheel area for a few months now. The knocking occurs when driving at or below 30 MPH. Ive taken it to the dealership like 4 times here in San Jose and they said that they would replace the strut but found no problems when thay took everything apart. wouldn't just be better to replace the shock and strut and then drive the car to see if it goes away?
Old Jun 7, 2008 | 06:21 PM
darkonion's Avatar
Chicks dig me. April Fool's!
Call one the BAIC's friendly shops and see if they can diagnose it for you.
Old Jun 9, 2008 | 10:58 AM
Racecomp Engineering's Avatar
Former Sponsor
Car Info: every subaru ever
It is common for OEM STi struts to clunk. You can open them up and add some lube and it should go away for a while.
- Andrew
Old Jun 9, 2008 | 11:45 AM
jinorazi's Avatar
Car Info: 05 cgm imp
i had the same problem, i tried replacing the axle nut front and back...this didnt help.
then when i put my springs installed, the noise was gone. found one of my rear end link broken so i position them so they wont rub.
Old Jun 9, 2008 | 11:51 AM
SubyN00by's Avatar
you can usually find low mileage used struts to replace the rear...or just do what we did and buy coilovers (=
Old Jun 14, 2008 | 01:11 PM
ApexAssassin's Avatar
Car Info: 2005 WRX STi, 1993 240sx (going under knife soon)
A friend of mine has a 2008 STi with the exact same problem. The noise is most audible when he is both accelerating and turning at the same time, and below about 25, as far as I know. There is also a vibration associated with the noise. Each vibration is roughly a quarter second from the next, and the total time is about two seconds, depending on the level of acceleration. He claims the car has been making said noise for a few thousand miles now, even though the car has only 7,000 total. I'll have to ask him if he's had it checked out.
Old Jun 2, 2009 | 04:21 PM
jgaultus's Avatar
Car Info: 2005 Subaru STI
I have a 2005 STI and within the last 2000 miles I hear a slight knocking/clunk sound when I am rolling very slowly (under 5 mph). It is coming from the passenger rear. It is not predictably constant (like every wheel revolution) and at times I believe that I can feel the car move slightly when I hear the slight "clunk". I have a feeling that it may be a wheel bearing but have not ruled out a CV yet.
bluebiker
Dec 21, 2005 03:22 PM
S4bones
May 31, 2005 07:49 PM
hashiriya
Jan 20, 2004 05:22 PM
BelfryExpress
Nov 20, 2003 07:44 PM
jumper
Sep 13, 2003 09:35 AM
