help! urgent! break pad help!
Old Oct 10, 2003 | 02:29 PM
onefasazn's Avatar
Car Info: 95 Legacy wagon
did you retract the pistons into the caliper before placing the pads on?
JAN
Old Oct 16, 2003 | 12:42 AM
Uncle Scotty's Avatar
It would seem that you might have made a mistake....
Did you have any 'leftover' parts?
They shouldn't 'raddle'.
Old Oct 18, 2003 | 12:58 AM
onefasazn's Avatar
if you have any leftover parts, they might be the retaining clips...
JAN
Old Oct 18, 2003 | 01:37 AM
wrexr's Avatar
Car Info: E28M5, RAM Powerwagon, Motos
Parts left over...
You might have transferred the clips, but how bout the backing plates. It is also a good Idea to put some of the red stuff between the backing plates and the back of the pad. Red stuff called "disk break quiet" made by CRC, can be found at your local Kragen for a few bucks. It is not necessary, but it is helpful to ensure quiet brakes. Oh yeah, the axxis pads might make a little noise over the stockers. It will go away as you heat them up.
-Hope this helps.
Old Oct 18, 2003 | 02:27 AM
Permatex makes their brake goop blue, works the same.
I'm loving my new brakes, BTW...
Old Oct 24, 2003 | 12:27 PM
qwk_wrx's Avatar
Car Info: 05' Evo 8
you probably left out the retaining clips...i alomost forgot them....defrinetly use the red brake goop on the retaing clips....quiets em down ALOT....
WRXnoob
14
Apr 8, 2006 04:42 PM
mwahaworld
Jan 30, 2006 02:20 PM
keirnna
Jul 26, 2005 11:05 PM
freeland169
Sep 16, 2004 08:20 AM
suby808
Sep 27, 2003 09:39 PM
