HELP! Cusco front sway bar installation issues on WRX wagon
Old Sep 25, 2003 | 10:51 AM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Are you sure you got the bar in the right way? I might be wrong, but from the pic, it sure doesn't look right.
Also, the bar is designed to work with stock end links, so any aftermarket endlinks might cause issues.
Old Sep 25, 2003 | 01:29 PM
I agree with Alex here... the bar isn't mounted right. That "U" shaped part should be horizontal, not vertical. I imagine the bar feels insanely stiff right now, right?
Old Sep 29, 2003 | 11:02 PM
HellaDumb's Avatar
Car Info: 72 Vespa with curb feelers
I have the same bar on my wagon and it ate up the upper end link bushing just a little after about a year and 20k miles... no biggy. =) (I just installed whiteline solid aluminum rear links and old-style whiteline front links with my Cuscos tonight... Yay!!!)
Old Sep 30, 2003 | 11:04 AM
HellaDumb's Avatar
old-stle =
I mean the "wire" looking links that whiteline sells. The design allows the bushing to pivot a bit, but not nearly as well as a spherical bushing.
JunGdB
26
May 9, 2006 01:07 PM
dropkick_muppet
Jul 16, 2005 12:13 PM
DaFastOne
Jun 22, 2005 03:53 PM
WRXWagon203
Jul 5, 2004 10:58 PM
