H and r problems
Old Mar 13, 2010 | 12:53 PM
Ikant's Avatar
Car Info: 97 impreza wagon
H and r problems
I just put h and r springs and kyb gr2 struts on my 97 obs wagon. The problem is that the left side sits lower than the right. What did I do wrong? I made sure to put everything back together properly
Old Mar 13, 2010 | 12:54 PM
silverbullet415's Avatar
i have h&r on my car and there fine
Old Mar 13, 2010 | 01:28 PM
Ikant's Avatar
Did you cut your bumpstops?
Old Mar 15, 2010 | 03:58 PM
Ikant's Avatar
No I was thinking about it, should I?
Old Jun 10, 2010 | 03:56 PM
nolan's Avatar
Car Info: 02 MBP wagon
In the interest of not making asusmptions, are you certain you're on a perfectly flat surface when you are examining the height?
Even a small bit of slope left to right will make it appear to be higher / lower on one side.
Also, if you just installed all this stuff, springs need a little time to settle. did you drive it around for a while and take some hard turns to let the springs settle?
Old Jun 21, 2010 | 12:10 AM
manapuaman's Avatar
Car Info: 2009 Subaru Impreza Outback Sport
And make sure the springs are sitting in the perch correctly
-WickedRex-
Dec 18, 2006 06:57 PM
grex767
May 27, 2006 10:37 AM
dorifto88
May 20, 2005 01:36 PM
Rekisito
Mar 17, 2003 01:33 PM
Purdue WRX
Jan 4, 2003 06:15 PM
