Help with Suspension
Old Jun 20, 2010 | 05:42 PM
Guillermo's Avatar
Car Info: DGM BRZ
Hey guys, I just bought JDM STi pink springs and was wondering what else I should pick up to get a great ride for street use and some spirited driving in the hills. The guy I bought them from said Koni Yellows and Tokico D-Spec's. Is there anyone with experience with this setup or another setup using the pink springs or something similar that can recommend something to me? Is there anything else I need to buy to improve ride quality and performance?
Old Jun 22, 2010 | 10:21 PM
Guillermo's Avatar
Car Info: DGM BRZ
Bump. Got these springs and looking for a good setup.
Old Jun 22, 2010 | 11:09 PM
Gancherov's Avatar
Car Info: 02 WRX Wagon
Well a nice and eventually necessary upgrade would be STI struts to go with those springs. You can easily find 04+ sti struts for $200-300. 04 sti stuff will bolt right in front and back for your 02 bugeye. The 05-07 rears will bolt right in but the 05-07 fronts take some modifying (expand the lower bolt hole upwards 0.330 inches and make some 2.5mm shims to make up for the wider strut->knuckle mount).
If you want to go a little further you can get some sway bars, i have an 05 sti 20mm sway bar that will bolt right in for you and reduce understeer noticeably for $50. Or you can spend a little more and get some even bigger swaybars, 22-24's seem to be popular for daily drivers. You can also get endlinks and heavy duty mounts. Full retail might run around $600 or so but used should only be $300-400.
Fender braces ($75), rear strut bars($30 ebay is fine), h-braces ($30 ebay again), and maybe camber bolts for the rear ($20-40) are also great bang for the buck and make noticeable improvements.
Old Jun 22, 2010 | 11:24 PM
Guillermo's Avatar
Car Info: DGM BRZ
Alright, thanks. So the Tokico D-Spec struts and Koni Yellow shocks would be fine, I'd just need some different top hats and then get swaybars, camber bolts, endlinks and h-braces to make great improvements on handling/suspension?
wrx 03i
Jan 10, 2011 04:27 AM
saltysti
Jul 11, 2009 09:04 PM
Deserted1
Aug 1, 2008 08:19 PM
bluekn8286
16
Apr 27, 2007 06:16 AM
DaFastOne
25
Aug 9, 2005 01:53 AM
