diagnose my problem!
Old Jun 1, 2004 | 12:08 AM
imprezey's Avatar
Car Info: 2001 Silverthorne 2.5RS
everytime i am turning there is this clicking sound that comes from the front. whether it is right or left there is a very audible clicking sound which follows the the rotation of the tires. what could it be?
Old Jun 1, 2004 | 12:19 AM
imprezey's Avatar
just did a search so it sounds like a cv joint problem.
now the question is, how much does these things usually cost to repair?
Old Jun 1, 2004 | 12:21 AM
Shiseiji's Avatar
Car Info: 1993 Impreza L sedan
I've got a 93 Impreza L and I replaced one for $70 (cost of part) and it took maybe 45 mins to an hour to put it in. No special tools needed, really, but it helps if you've done this sort of thing before.
Old Jun 1, 2004 | 12:55 AM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
If you are using SS brake lines, it might be them. If you did not install the support bracket properly, they would be touching the inside of the wheel (wheel weights) during cornering.
Old Jun 1, 2004 | 05:55 AM
nosnam's Avatar
Car Info: 2003 subaru
did you change or reconfigure your struts? IF so make sure your top hats are straight because that would cause the springs to bind when turning, if they are staright make sure they are put together correctly. When you turn they are binding then popping
Old Jun 1, 2004 | 09:48 AM
imprezey's Avatar
hm my problem seems have gotten worse. the clicking sound is now really loud and clicks when i go either forward, right , left. havent checked out reverse yet but im sure it would click at the same time as well.
Quix_
Aug 5, 2015 01:39 AM
fastfamilywgn
Apr 30, 2006 09:42 PM
Fatty McBastard
Jul 16, 2005 12:31 PM
TastyTurbo
Aug 20, 2004 12:38 PM
Ken Berg
Aug 5, 2004 09:21 AM
