brake line/strut issue
Old Apr 14, 2005 | 03:35 PM
emyselfandi's Avatar
i was eyeing up swapping the struts on my 95 sedan (BD right??). There is a thin brake line (ABS Line???) that is bolted to the body by 2 bolts.. This is not a problem. There is another larger brake line that is attached to the strut. The metal piece that is welded to the strut looks like the rubber hose goes through the center... So my question is how do you get that brake line off?? does it have to be cut or replaced?? I can't see how it pulls off of that metal holder/clip. Thanks, Tim
Old Apr 17, 2005 | 12:25 PM
DLC's Avatar
DLC
Car Info: 2000 Leg GT LTD
To avoid having to remove the line from the caliper, cut through the bracket to get the line out.
kyoung05
Jan 31, 2010 11:40 AM
mcowger
Jan 5, 2009 06:07 PM
jackov
Sep 24, 2008 11:55 AM
Meimei
Nov 7, 2007 07:27 PM
bringndefinitio
Mar 17, 2006 03:53 PM
