power steering pump into brake fluid line
Old Apr 17, 2005 | 03:33 PM
NeRdY DoRkUs's Avatar
so this one tuner shop said they could either take my power steering pump and reroute it into the brake fluid lines to create pressure in the system. im sure this would make a pretty big improvement in braking without bubbles and what not. or they could just take another power steering pump and pop it in so i would have power steering also.
thoughts?
-andrew
Old Apr 17, 2005 | 06:46 PM
Wingless Wonder's Avatar
Origami posted by NeRdY DoRkUs
thoughts?
Wow, where to begin.
This has been done by some manufacturers as a brake assist, much like the conventional power-assisted brakes that rely on engine vacuum. Ask youselves these questions: What advantages does it offer for a Subaru? Does it correct some known deficiency with the factory brakes? How much power would it consume to drive an additional pump? Would the factory ABS still function correctly if modded in this manner? Last, but not least, this is sure to void any factory warranty should you have some sort of brake problems.
JMeltzer4
Aug 17, 2010 07:23 PM
jackov
Sep 24, 2008 11:55 AM
bringndefinitio
Mar 17, 2006 03:53 PM
kalasend
Sep 18, 2003 11:06 AM
jumper
Sep 10, 2003 05:16 AM
