big brake kit
Old May 1, 2003 | 03:01 AM
gqzboy's Avatar
Car Info: 02 wrx wagon
big brake kit
which big brake kit should i consider getting
1) stoptech which is $1695
2) wilwood big brake kit $1295
My question is.. is it worth it to spend the extra 400 dallors for the stoptech? they are both 6 piston. which is better in your opinion? thanks for the input
Old May 1, 2003 | 01:40 PM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
Danny if you did a little research you would have found that the stoptech system is highly regarded on this board.
However if you ever plan to run stock wheels again, your out of luck as the wheels wont fit.
But that is where the iON Performance kit comes in. Big brake kit, 4 piston, and you can use the stock wheels as well.
Old May 1, 2003 | 02:26 PM
teiva-boy's Avatar
Originally posted by Zahnster
I like how the Ion kit is considered a BBK for adding 10mm circumferance
I'm sorry for assuming that there is a certain number that a brake kit has to pass to call it a "BBK"
Point of the matter is the rotor is larger thus reducing fade over the stock system. On top of that it's a two peice rotor. The benefits are much much more then the measily 10mm you mention.
Old May 1, 2003 | 04:43 PM
gqzboy's Avatar
how much are ur kit?
ion
i went to your website.. it really has nothing, no product listing.. turbo rebuild info.. i would like so info and prices.. thanks
