Alignment settings post em!
Old Dec 31, 2011 | 04:14 PM
Urban_Grey_2.5's Avatar
Car Info: Norco 29er Mtn Bike
where do you guys get these fancy alignments? lol
Old Jan 3, 2012 | 08:11 AM
RiSky's Avatar
Car Info: RWD SR20/Impreza
Performance Options in Oakland, CA (7th Street) does great alignments at a decent price. Talk to Joey
Old Jan 6, 2012 | 08:54 PM
Probably going to go to auto innovations in Millpitas
Old Feb 9, 2012 | 04:53 PM
bikelok's Avatar
Car Info: 2002 wrx wagon
2002 wrx wagon
Front:
Camber left -2.0 right -2.0
Toe. left 0.00 right 0.00
Rear:
Camber left -1.5 right-1.5
Aligned at 5 Points in Redwood city.
Old Feb 16, 2012 | 01:14 PM
SkizzDawg's Avatar
Car Info: 2006 STI
Im having new tires put onto the car and they are going to check the alignment and see where its at (Firestone). Currently the car drives straight and handles like a dream tire wear looks great and seems even. I am looking through this and trying to come up with a good idea on a number to tell them i would like my car set to.
I would like some input and suggestions. My car is an 06 STI, I have some sort of aftermarket strut insert with Swift springs, I have full sub frame bracing from back to front, H brace, White line ALK, White line Roll center, I have spherical tie rod ends, after market C links for the sways, possibly sways but cant tell they are black and no stickers, and i have the camber bolts front and rear at least thats what i read on one of the receipts the previous owner gave me. I DD my car and i do a lot of canyon runs and at times drive aggressively. Im not a fan of under-steer one bit (my FWD days are behind me and even then i had my car set up to under-steer as little as poss for a FWD). I would like my car to handle and corner at the very least as well as it does now if not better.
I saw buzzword post these specs (he has an 06Sti) but he has coils and camber plates so im not sure how close i can get my car to match those numbers.
front: -1.5 camber 0 toe +4 caster
rear: -.5 camber 0 toe 0 caster
Any suggestions for settings?
Old Feb 16, 2012 | 01:23 PM
JourdanWithaU's Avatar
^^Unless you have camber plates, I don't think you can adjust the caster. -1.5/-0.5 should be cool. But I don't know much in regards the the GD chassis.
Auto Innovations FTW!
I'll probably be paying them a visit in the near future.
Old Feb 16, 2012 | 02:15 PM
SkizzDawg's Avatar
Car Info: 2006 STI
Thanks for the input Jordan. That's what i figured. I'm still finding out and learning what all the previous owner installed on the car suspension wise. I just want to make sure my car is not set to the "standard vanilla" alignment setting and set to something similar to what i have now or better.
Old Feb 16, 2012 | 07:43 PM
bikelok's Avatar
Camber does not usually kill tires. Many people run as much as -2.5 degrees up front with little tire wear. Toe eats up tires.
Zero toe is key!
Old Feb 16, 2012 | 10:34 PM
CcaniaSTI's Avatar
Car Info: Flared laguna seca GD
Here's mine camber front L 2.9 R 2.0 toe 0
Rear L -2.6 R -2.6 toe 0
Dropped on Megan's coils
Old Feb 17, 2012 | 10:52 AM
queeg9k's Avatar
How come almost a degree more on the left? Like going around on-ramps?
Old Feb 17, 2012 | 11:20 AM
SkizzDawg's Avatar
Car Info: 2006 STI
i was wondering the same thing.
Old Feb 17, 2012 | 12:54 PM
bikelok's Avatar
If he brings his left front down to -2.0 to match his right, he will have more negative camber in the rear compared to the front. Ccania STI, you should try to get your right front to match the left. That would put You in a good place.
Edit: look at my post #29. That is what I was trying to say here. Sorry for any confusion.
Old Feb 17, 2012 | 12:58 PM
More camber in the rear than the front? I don't think that's a good place.
Old Feb 17, 2012 | 01:04 PM
bikelok's Avatar
Thats what I am trying to say. If he brings his right front to -2.9 to match his left, that would be better than bringing the left down to -2.0.
The bottom line is he should have:
Front, left -2.9/right -2.9
Rear, left -2.5/right -2.5
Old Feb 17, 2012 | 01:25 PM
Originally Posted by bikelok
if he brings his left front down to -2.0 to match his right, he will have more negative camber in the rear compared to the front. Ccania sti, you should try to get your right front to match the left. That would put you in a good place.
thats what i am trying to say. if he brings his right front to -2.9 to match his left, that would be better than bringing the left down to -2.0.
rear, left -2.5/right -2.5
wat
