'98 IMPREZA OBS Mysterious Rear Drum Noise!!!
Old May 4, 2005 | 07:24 PM
scoobsport98's Avatar
Car Info: 98 Impreza Outback Sport
wheel bearing is done for...
I also have a 98 OBS, and had to replace my left rear bearing. They used unsealed bearings in the rear of our cars, and it's a very common problem to have them go out. They have updated the replacement part # (a tapered, roller-style sealed bearing), which are stock in legacy models. If you need the part #, I can get it for you- I've got it somewhere.
When mine went, I could only notice it at slow speeds at first. But stared to sound worse and worse and I was eventually able to tell at all speeds. You can do more damage (to the hub, etc) if you drive on it too long
Old May 5, 2005 | 11:45 AM
Fatty McBastard's Avatar
Car Info: impreza ob sport
I'm going to need new bearings for my OBS. I would like that part number. Do you remeber the price?
Old May 5, 2005 | 12:43 PM
Not totally sure if these apply to your year- but this is what I got for mine (just one side):
28016AA030 bearing assy. 74.50
28015AA050 oil seal 12.54
28015AA100 oil seal 12.16
28015AA110 oil seal 13.50
total parts: $ 112.70
total labor: 2.4hrs $ 153.60
~$265 per side...
if you need more info... I've got a copy of the 'Endwrench' service bulletin where it outlines the procedure-
looks like they charge now http://techinfo.subaru.com/html/ixSe...rd=&bulletin=3
Old May 5, 2005 | 10:06 PM
mule2k's Avatar
I have a '00 Impreza L, and for the past few weeks I've been hearing a high-pitched squealing coming from the right rear at low speeds. Is this like what you're talking about? My car has 33k miles on it, so I hope it isn't a wheel bearing. Anyway, I've got an appointment to get it checked out next week.
Old May 6, 2005 | 08:18 PM
Here ya go: the first is just a 'notice' about the change, the second one is the one I have (which shows most steps)... the bottom one (8mb) is the complete procedure...
http://www.endwrench.com/current/Cur...s/03-50-02.pdf
http://www.endwrench.com/current/Cur.../WhBearRep.pdf
http://www.endwrench.com/current/Cur...MSA5TT0201.pdf
have a ball
Old May 10, 2005 | 08:22 AM
Thumbs up
scoobsport98 thanks alot for posting the endwrench links. they convinced me to take it to a dealer. the price of the tools i would have to buy, is far more than the dealer installation price. thanks for being so thorough
Old May 10, 2005 | 10:37 AM
Angry What The *@%$
So I just called the "stealership" and asked what they would charge to replace the rear wheel bearing..... ready for this? they said it would be $400 dollars. $425 if I wanted new lug studs. that is outrageous! how accurate was the $265? was that a dealership?
Old May 10, 2005 | 11:07 AM
Nope- that was my local mechanic (who happens to specialize in Subarus). I bought and picked up the parts from the dealership and had him install them- it was weird because he had recieved the bulletin and knew about the new part # and procedure, but the dealership knew nothing about it at the time...
If you have a mechanic order the parts for you, he will most likely make a little $$$ on them- so this is the cheapest route.
The parts may be more expensive now, I had this done a couple years back- but most of the difference is probably in the labor costs. So I guess you want to look around for a reputable import mechanic in your area- good luck
And no problemo on the links... just took a google search
Rad One
Subaru OEM Parts For Sale
Mar 23, 2005 04:54 PM
Rad One
Dec 3, 2004 10:21 AM
LordWorm16
Jul 30, 2004 08:29 PM
LEDTech
May 28, 2004 06:19 PM
