03 wrx front brake pads
Old May 29, 2003 | 05:29 PM
EWThompson13's Avatar
Why Change Caliper Sizes????
I'm glad I took a look in this forum before getting into swapping out my stock pads for the Hawks that I bought about 2 months ago. You are absolutely correct, the tab on the new pads is widder than the slot in the caliper. My thought is to grind the tab down so it will fit. Does anyone see and problems with doing this? I don't see how strength would be compromised given the fact that the caliper slot is made for this smaller sized tab. Anyone have any thoughts, because I would sure like to have the Hawks on for an upcoming track day!
Old May 30, 2003 | 10:55 AM
MY03 pad swaps
ttt. Anyone have any opinions on modifying the tab of the brake pad so it will fit into the MY03's smaller slot in the caliper??? I'd like to do it this weekend if I can get any kind of feedback here.
Old May 30, 2003 | 09:05 PM
Angry
Damn Subaru. Why change a caliper for 1 fricken year!!! So, the Hawks are out for now. Is there another performance pad that anyone knows of for an 03 WRX?? I can't believe I have to upgrade to a big brake kit to get some decent pads on this beast!
Old Jun 1, 2003 | 05:46 PM
nqwan's Avatar
Car Info: o2 duburu arr exu
if you want ceramic pads try carbotech bobcat pads. they have them for the 02's and the 03's. actually, i have a set of the front 03's here because i need the 02's but was sent these instead.
oh and if you're going to get the rear pads from carbotech, make sure you grind the nubs on the back of them off before putting them on. otherwise only ~half of the pad will contact the rotor. you also wont be able to use the little squeel tab with the carbotechs.
you can get the carbotech's from subydude.
Old Jun 2, 2003 | 05:10 PM
Thumbs up A Huge Thanks
Thanks for the info on the Carbotechs nhilteb!! Looks like suby_dude will be getting some more of my money in the next couple of days. One more question, are the Panther's a bit extreme to run on the street as a daily driver? What I've read, it seems like these need a little heat in them before they begin to perform, which is not always ideal on the streets. Thanks again.
pyrilium
Apr 26, 2006 08:26 PM
mbquarts
Nov 2, 2005 03:22 PM
BlueSti389
Mar 24, 2004 07:12 AM
WorldONE
Vendor Group Buys/Specials
Dec 11, 2003 10:43 AM
