Loud engine noise
Old Aug 31, 2004 | 01:17 PM
wrxout's Avatar
get the CEL checked! how would you express the noise?
Old Aug 31, 2004 | 08:39 PM
imporacer's Avatar
Red face
What he means is the Check Engine Light (CEL). There's an OBDII diagnostic port right below the driver side dash. Looks like a computer connector. But in order to read the CEL codes, you must have a scan tool and the only people that can read it is your dealer for about $80, or a local auto parts store for free. Good luck on this one.
On your engine noise, pop the hood while your engine is running to verify that the noise is coming from the engine bay itself, not from the wheel bearing. If it does, chances are it could be a pulley bearing going out from one of the accesories (alternator, P/S pump, A/C compressor or tensioner pulleys). However, from the way your explaining things, you might have a wheel bearing problem cause it occurs while your driving. An engine noise underneath the hood will be constant with the engine running. I hope this help and good luck on the CEL code.
imporacer
mateusz
Jan 10, 2005 10:00 AM
LordWorm16
Jul 30, 2004 08:29 PM
Ayapon
Dec 29, 2003 05:04 AM
wrcsti
Dec 12, 2003 05:22 PM
cherrywrx
Sep 30, 2003 02:39 PM
