how can we prevent engine overheating?
Old Mar 19, 2007 | 09:46 PM
bigg_kidd's Avatar
Car Info: PSM STi
btw, how can we prevent engine overheating? i got an 05 STi, (sorry to hi-jack the topic), and sometimes things just makes me think that after a long drive, the engine is getting to overheating edge, does installing a cooling panel will help or not? any suggestions would be great, and if i am in the wrong section, plz re-direct me!! thx.
Old Mar 20, 2007 | 04:27 AM
Mulder's Avatar
Car Info: 02 WRX WRB
Normal driving, even hard driving, should not result in overheating unless there is something wrong and/or the car is significantly modified and making well over stock power levels. The factory cooling system is sufficient as long as the car is properly maintained.
Old Mar 20, 2007 | 09:32 AM
dan2304k's Avatar
Car Info: '07 FXT Sport / '96 STiL
Factory cooling system on the STI is quite good. In Best Motoring's endurance test, the STI was perfectly fine while other cars (BMW M3, RX7) were having heat problems. I don't think you need to worry about it.
Old Mar 20, 2007 | 04:15 PM
cbf246's Avatar
Car Info: 04 WRX
if youre really into preventing overheating, then upgrade everything. thermostate, hoses, radiator, cooling panel, etc. but regular maintanance is way cheaper.
Old Apr 1, 2007 | 05:23 PM
Toiletbrush's Avatar
Car Info: '94 WRX, '97 Forester S/Tb, '95 WRX-RA
I am also curious about an overheating problem I have that only happens at the track. After running for around 30 minutes on the circuit, toward the end of the session, the aftermarket temp gauge spikes, even though I do a cool down lap to try an prevent this. The stock temp gauge raises slightly, but nowhere near the 'H'. When I return to the pit, I find that a significant amount of coolant has spilled from the overflow (about a 1/2 liter).
There is no power loss, no coolant in the oil or vice-versa, no smoke from the tail pipe... nothing that would indicate a head gasket going bad. I am running a 16lb cap (1.1bar), and the rest of the cooling system is stock. I was about to shell out for a 60mm radiator and hoses, but it was suggested that it could be some other problem causing this that a larger radiator would not fix.
Next question is, does elevation and atmospheric pressure play any role in how efficient the cooling system performs? The track I go to is built on top of a mountain. Any physics gurus out there?
Old May 1, 2007 | 02:51 PM
-=turbowrx=-'s Avatar
Car Info: 2003 aspen white wrx
get a egt gauge
vietpunk916
May 7, 2007 09:54 AM
HellaDumb
Mar 14, 2006 08:23 PM
restricted_wrx
Jul 2, 2004 12:29 PM
six1five
Apr 1, 2004 02:37 PM
fyxtion
South-West
Jan 4, 2003 12:11 PM
