check engine light
Old Jan 15, 2005 | 10:17 AM
xwarrenx's Avatar
check engine light
last night i was driving home about 12 i was in 5th gear going about 50-60 then all of a sudden my check engine light poped on and then the cruise controll light started flashing on and off?? the mods i have are
blitz bov
gt spec headers and upipe
jic exhaust
hks short ram intake
and i had a downpipe but i ruined it by crashing my car so my stock one is on until i get more money to get another one and i have the cell flex thing is stll on
any ideas on what is wrong with my car??
MY CAR IS A 05 STI
Old Jan 15, 2005 | 10:58 AM
slvrsubywgn's Avatar
I'm assuming you own a rex...Subaru had a recall on one of their cruise control parts a fewyears back. Dunno if that's it but you might want to check it out.
Old Jan 15, 2005 | 11:00 AM
Mulder's Avatar
Car Info: 02 WRX WRB
The cruise light flashes with the CEL to get your attention, there isn't anything wrong with the cruise control.
It's impossible to speculate here on what caused the light to come on because there are literally hundreds of different conditions that can be detected by the ECU to set codes. You need to have the code(s) read and then come back and post it (them) here. If there is an Autozone near you they will scan it for free, unless you are in CA where I believe they loan you the scanner for a deposit and you scan it yourself. Alternately you can find someone in your local area who has a scanner and can check it for you.
When you do get it scanned, be sure to get the actual numerical code(s) so we can help you more accurately. Sometimes Autozone will just tell you the code is for a "sensor" and not give you the #, which is useless.
edit- and to address the above post, this has nothing to do with the cruise recall.
Old Jan 15, 2005 | 02:38 PM
imporacer's Avatar
Smile
Mulder is right, CEL only monitors the emissions systems, sensors, and ignition systems of your vehicle. The cruise control has nothing to do with it. I'll bet is that downpipe or fuel gas cap. Anyways, go get the codes from your local AutoZone so you'll have a pretty good idea what's going on.
Old Jan 18, 2005 | 10:12 PM
xwarrenx's Avatar
aRE THERE ANY other sujestions out there what it could be??
Old Jan 18, 2005 | 11:03 PM
Nick Koan's Avatar
Car Info: Legacy GT
go to Kragen, or some other auto parts store and rent an OBDII scanner. I think its only like $20 bucks or something like that.
Attach it to your OBDII port (under the steering column) and read whatever codes you find here. That will help us narrow it down.
Without that other information, we won't be able to help you too much. It could be anything. O2 sensor, misfire, cat inefficiency, etc...
Old Jan 18, 2005 | 11:53 PM
lex wit da rex's Avatar
ok kool thanx i will go do that i think the shop told me the light goes on because the 02 sencer reads theres no cats but i will go to kragen and get that things thanx guys for all the help.
Old Feb 1, 2005 | 10:36 PM
xwarrenx's Avatar
found out what it was one fo my grounding wires came lose and the bolt fell off so yea haha
Racerkid
May 29, 2012 06:16 PM
saab92x
Mar 16, 2009 03:16 AM
06scooby
Oct 15, 2006 10:11 AM
rash
May 17, 2003 12:32 PM
