Subaru OEM Parts For Sale Subaru OEM new and used car parts can be listed here only!
Checking interested full 2.0 motor
Old Aug 15, 2006 | 01:07 PM
BLK05's Avatar
Car Info: 2005 Black WRX
full 2.0 wrx motor, wiring, ecu, turbo etc. Its a 2005 with 30,xxx miles on it
parts include everything
crank
rods
pistons
block
heads
cams
manifold
alternator
p/s pump
a/c compressor
turbo
intercooler
engine mounts
header
uppipe
blah blah blah etc. etc. the whole shebang let me know if interested and shoot me a pm
also for sale at this time brand new wiring harness which runs around the car and through the firewall and a aem short ram intake
Old Aug 23, 2006 | 01:50 PM
crazyshifter928's Avatar
Car Info: 91 integra
how much did you want for the motor? and do you have a picture of it
Old Aug 24, 2006 | 09:51 AM
BLK05's Avatar
actually sir ... i decided against the swap i dont have the time or money so im now selling a 2.5 sti full block...
Going price is down to 2250 due to the cam pulley and what not...
Well I went ahead and did a cylinder leakage test (clt) and I found 3 of the 4 cylinders
to be in good shape although the other cylinder might be fine I just didn't have the strength
to move the cam over to make sure it was not holding the valve open also upon further
inspection I saw another cam pulley had a chip broken off of so I trashed that but other then
that the motor for the price im willing to go is more than a bargain. full list of parts I
have pictures and a video to prove the leakdown test and will send that to emails
consist of
block and internals
heads and internals
coils for all for cylinders
all the wiring that connects to the motor and sensors on the motor including one in the header
upper and lower radiator hose
and hoses that run through the and around the engine (vacuum hoses etc. etc.)
inlet tube
turbo coolant resevoir
turbo vf39 usdm sti
belts
aftermarket light weight crank pulley
turbo xs manual boost controller
tgv's
intake manifold
throttle body
oil fill tube n cap
p/s pump
alternator
a/c compressor
flywheel
engine mounts
oil pan
oil pump
BLK05
Aug 15, 2006 01:14 PM
SubWrxkid
Wanted
Jun 24, 2005 05:31 AM
stealth-wrx
14
Jan 26, 2003 09:27 PM
