Swapped engin won't start! Help.
Old Nov 13, 2012 | 04:15 PM
SubieDude05's Avatar
Car Info: 2005 Subaru WRX
Ok so my ej20 blew a rod bearing and I dropped in a used ej20 with around the same mileage 59000. Now that everything is put back together it wi barely start and if I does it wants to die right now away. I got it running for a couple mins once and it was misfirring on 2 and 3. Plugs were just changed and I tried swapping coil packs to no avail. Please any suggestions...could I have missed something with the install? How do u check for timing to be off a tooth since it was from a wreckers? Thanks
Old Nov 13, 2012 | 04:29 PM
MarvZz's Avatar
Car Info: 03 wrx
you have to pull the timing covers off to check timing.
you didn't change the timing belt while the engine was out??
Old Nov 13, 2012 | 07:00 PM
Check it with a light or just crank it till the marks line up and see. No i couldn't afford it on a very limited budget, but I inspected it and it looked great no cracks plus the engine only has 59xxx timing change not till 95 or 105 I forget
Anything else to look for? I'm checking spark right now and so far good on 2 and 4
Old Nov 13, 2012 | 08:27 PM
I have an accessport is there any sort of live data I can monitor while it's running that might help?
Old Nov 19, 2012 | 06:35 PM
b00st_addict's Avatar
Car Info: 2002 wrx
Did you try the simple stuff? Like checking the ground for the fuel pump. There is one on top of the intake manifold! I did a build got it all back in and forgot that one lead and ... No start bolted it up and it's back on!
Old Nov 27, 2012 | 08:44 AM
SUMBARU's Avatar
Car Info: 05 LGT Wagon, 06 LGT Wagon
Check your fuel lines. Might be flip flopped.
Old Dec 21, 2012 | 12:48 AM
wrx_sti_turbo's Avatar
Car Info: 2008 subaru impreza wrx sti
it doesnt sound to much like timing in my opinion, did you check all the sensors? maybe the engine has a bad sensor.
Posted from I-club.com App for Android
Old Sep 27, 2013 | 10:52 AM
Well my thread is super old but I figure ill update in case anyone else has the same problem. Timing was off. Came like from the parts yard so double check if you ever get one. Thanks for the help.
Dynapar
Jul 28, 2009 01:45 PM
Slyder626
Oct 14, 2005 11:13 AM
Wagon Joe
Dec 10, 2003 01:18 PM
EddyRS
Oct 18, 2003 01:29 PM
