smoking engine/ turbo
Old Jan 6, 2014 | 06:21 PM
phunhawg98's Avatar
Car Info: 03 wrx imprezza
ok heres the deal
03 Subaru wrx sedan, 129 k miles 3rd owner
every once in a while no particular thing brings t on, but I will see oil smoke (and can smell it) coming out of the scoop, I have not been able to catch it as it is doing it. well this afternoon I to see where the smoke was coming from.
it is coming from the turbo, cant pinpoint it due the heat shield on the turbo.
herein is my issue being new to the subee world.. what im I looking for, replace the OEM turbo, rebuild it, why is oil smoke there?
what is the stock turbo(v34??) if the turbo is going, then I would rather jut replace it, there are no mods to the car at all.
please help I clubbers, I need some direction
Old Jan 6, 2014 | 07:06 PM
southsti's Avatar
Car Info: 2005 OBP STI
I would check the valve cover on the passenger side. If you haven't replaced the gaskets it's more than likely leaking onto the exhaust manifold/heatshield below it.
Old Jan 7, 2014 | 01:10 AM
suBiElove04's Avatar
Another way to check to see if the turbo is leaking would be to take the intercooler off and see if the oil has made its way to the throttle body. It happened to my 04 sti.
Just thought I'd share my experience.
Old Jan 7, 2014 | 05:38 AM
phunhawg98's Avatar
and if the turbo is leaking into the TMIC what repair am I looking at? rebuild it, replace seal replace it all together
when you had oil in the TMIC what symptoms' were you experiencing
Old Jan 7, 2014 | 06:24 AM
leaferiksin's Avatar
Car Info: stock
this...
Had this happen to me a few months ago.
Old Jan 7, 2014 | 07:12 AM
ddavis's Avatar
Car Info: 04 wagon
Check your oil lines on your turbo also.
Old Jan 8, 2014 | 11:11 AM
It threw 3 codes at me, po123, po304, and po108.
The po108 went away when I cleared them just to see if they would come back, but the other 2 came back. I was loosing a lot of oil, and gradually loosing boost, eventually the turbo shaft split in half and I lost all power. The motor had over 200k miles on it so I was planning on pulling it anyways, but that's what happened. I would replace it with a new one. There's not a big market for rebuilding the vf39 turbos. You can get rebuild kits on eBay, and a few other places online, but ya know, I would just get a new one.
Tchsssss
Dec 19, 2003 11:18 AM
bao ling
Sep 8, 2003 02:32 PM
aloose
Jun 8, 2003 04:30 PM
EtchyLives
May 17, 2003 11:21 PM
ted1186
May 3, 2003 09:57 AM
