Driving long distances at high speed
Old Jun 18, 2004 | 07:36 AM
Red Bar0n's Avatar
Car Info: Red 04 WRX Wagon
Oh
Originally Posted by Wutzdatbehindu
Red Baron...
The car is an 03 WRX. She already has 22000 miles on it. The commutes from Elk Grove, UCDavis and CSUS are adding up miles like crazy.
Do you regularly maintain the car?
I ask about the age of the car and this maintence question b/c older parts or an unmaintain car would have more of an impact on the wear of your engine.
Old Jun 18, 2004 | 07:50 AM
Subaruski42o's Avatar
Car Info: 98 RS
Isnt that what cars are made for. To drive?????????????????/
Old Jun 18, 2004 | 11:18 AM
meilers's Avatar
Originally Posted by qship
the rule of thumb in automotive engineneering is a motor can be run at 2/3's of it's redline for long periods of time with out any undue wear. boats and airplane motors will have their crusing speed set at about 2/3's of the redline. also see in the forester forum boston to oakland in 56 hours of driving.
To my knowledge this is correct. In fact, many engines run cooler and with less wear at mid- to high RPM than they do at very low RPMs or under heavy load (acceleration). As long as your cooling system is working well and your lubrication is optimal (clean oil and oil filter) you've got a far greater chance of damaging your engine by actually wrecking your car than by simply driving it at a constant speed. As someone else pointed out, you put MUCH more strain on an engine and drivetrain when accelerating than you do when cruising at a constant speed. I think 100 miles of "jackrabbit" driving (fast stop, fast start) would do much more damage to an engine than 300 miles of 75 mph with the cruise control on.
Now, if only the WRX (or any Suby) had a decent factory temperature gauge, and not these idiot gauges that will only tell you if you have a problem about 2 minutes before you actually overheat...
Old Jul 12, 2004 | 11:51 AM
sampson's Avatar
No, your car is meant to be driven.
huck
Nov 15, 2005 12:13 AM
DrNorm
Nov 2, 2005 05:49 PM
808subaru
Oct 18, 2005 02:56 PM
Wingless Wonder
Mar 15, 2005 04:05 AM
bogusbob
Mar 23, 2003 09:43 AM
