Brake Help
Old Mar 9, 2003 | 06:26 PM
Mulder's Avatar
Car Info: 02 WRX WRB
ABS is not a factor when you are just replacing the pads, you do it the same as any other car with or without ABS.
The noise is the metal wear-indicator tab on the pads contacting the rotor. There is nothing to reset when you change the pads, just check the brake fluid level AFTER you have changed the pads and pumped the brakes back up. The fluid may be low now because the pistons have moved out behind the worn pads, but it will go back up when they are retracted to put the new pads in.
RavSpec
Apr 15, 2006 09:13 AM
OakosAutomotive
Vendor Group Buys/Specials
Nov 12, 2004 12:02 PM
BlueSti389
Mar 24, 2004 07:12 AM
StopTech
Sep 3, 2003 01:32 PM
