22-Wannabe? Need help...
Old Dec 9, 2003 | 09:12 AM
onikageka's Avatar
Question 22-Wannabe? Need help...
Sup all?
Ok, so I'm looking for some pretty indepth info here. I am considering trying to made a 22B replica is most respects. I know that I can get the flared fenders as part of a kit. Here's what I'd like a quick Yes or No on...
Will a 1995-1996 Impreza have the same body as the 2000?
- As in, will a JDM STI hood fit the 95?
- Will the STI Ver 5 front and rear bumper fit the 95?
- I would like to do a USDM 2.5L STI engine and tranny swap. Since all Impreza's are basically same it would be no harder to do this in the 95 car than the 2000 car right?
- I've been told that suspension components that fit any Impreza can be swapped to pretty much all Imprezas. True?
- Can the 2000 or maybe even 2003 interior be fused into the 95?
From the research I've done, I believe all of this is doable in a pretty much "bolt in" fashion. I don't mind doing all the work myself (That's half the fun). But I don't want to have to custom fabricate a ton of parts to do it.
Thanks for your help Suby experts.
Old Dec 9, 2003 | 09:50 AM
The Mirror's Avatar
It all sounds very doable to me except the 2003 interior. That one might take some effort (read: $$$$$$$).
Old Dec 9, 2003 | 09:54 AM
onikageka's Avatar
Cool. So the chasis for the 1995 and the 2000 are the same, just with different body panels and interior?
Old Dec 9, 2003 | 01:47 PM
onikageka's Avatar
What is the chasis code for the 1995 Impreza? Is it also GC8?
Old Dec 9, 2003 | 01:58 PM
Wingless Wonder's Avatar
Chassis codes, courtesy BAN SUVS.
Old Dec 9, 2003 | 02:08 PM
JohnQGearhead's Avatar
Car Info: '00 RS, Subrosa Letum
Around these forums, GC8 is kind of a generalization for old school Imprezas. I don't want to reffer to my car with the letters G and M ever! Even though it's a GM6.
I have had this 22B idea for quite some time as well.
I wonder why I haven't heard of any real 22B owners on the i-club. They could answer alot of questions for us.
Old Dec 9, 2003 | 02:57 PM
Choku Dori's Avatar
Car Info: Corvette Z51
It's b/c they're all overseas, and 90% are Japanese
Good luck on your project, I'd love to see pics if/when you finish your 22(wanna)B Just kidding
Old Dec 9, 2003 | 03:01 PM
onikageka's Avatar
Well if the tranny and engine won't fit as a straight swap... Then I might as well get a 1998-2000 2.5RS, build the engine and swap in the DCCD 6Speed. Sides, with a built motor I can probably get 300+whp on pump gas.
Old Dec 15, 2003 | 08:39 PM
ilgdrummer's Avatar
Car Info: Still Looking
What year L is best suited to be converted to a 98-01 rs body style, sti engine, suspension, interior, etc.?
Or is just cheaper to start out with a rs because by the time the body of the L is converted the rs,will I already have spent more then the rs costs?
Old Dec 16, 2003 | 01:11 AM
brucelee's Avatar
Friendly Neighborhood Ogre
Car Info: GUNATICS.COM
Everything will fit as long as you use the same model year parts. For example, if you bought a 94 Impreza L, and decided to convert every part to a 2000 spec RS (or V6 Impreza), you'd have to match the following:
Headlights
Grille
hood
bumper (bumper can be V3-6)
rear bumper is the same on all cars (meaning, any of them will fit).
The most important thing is the headlights/grille/hood. Since they are year specific.
Good luck.
Old Dec 16, 2003 | 12:02 PM
ilgdrummer's Avatar
Wow, thank you. So basically if I start taking parts from a 2000 rs make sure all the parts are from the 2000 rs, not mixing between 98,99,00,or 01.
Old Dec 17, 2003 | 12:56 AM
British Banger's Avatar
Underpants Gnome
Car Info: 1.4 Ford Fiesta
Originally posted by wrxwagon2b
Good Luck with the 22B project but read what I said b4 and Ill clearify it here again. The area where the Tranny/drivetrain is on the GC8 model is TOO Narrow to fit a USDM EJ25t's 6 speed tranny and the DCCD. You have to widen the area in order to fit it in.
If you put in the EJ25t and DCCD in a GC8 successfully then it wont be a 22B (replica) anymore... it would be more unique.
Due to the body change in 02 all imprezas arent exactly the same. For your project it would be easier to get a 00 RS. Get a JDM EJ20t and a .2lt stroker kit and make your 22B replica engine, get some JDM parts and Tranny, a Cusco Rear LSD etc...
Not too many ppl if any have done a GC8 with a USDM EJ25t with 6 speed Tranny/ DCCD. If you do do it... you are the Man!! and a Broke man at that
Do the usdm 6-spds have the same dimensions as the j-spec 6spds? I ask because there have been a few people online (I-speed) who have put j-spec 6 spds into the GC8 bodystyle without ANY problem with the tunnel being too small. There is no need for a hammer when installing one, that is just a dirty rumor .
onikageka, I believe if you go with a widebody 22b kit, you have to use a 22b front and rear bumper. I am not completely certain about this, just an observation since the bumpers has to come out to meet the fender flares, where a regular bumper wouldn't.
FYI www.aerosim-research.com is wrking on a carbon fiber kit for GC8's, I am waiting for the wagon kit
James
Old Dec 17, 2003 | 02:02 AM
brucelee's Avatar
Well, I know 99-01 are the same (headlights/grille/hood). 98 and below are all different.
So, if you stick with 99-01 RS parts, you'll be fine. (99-01 style looks better)
