TW: Built 07 STi Engine for a Stock 07 STi Engine
Old Jul 1, 2009 | 09:34 PM
NorCalDC5's Avatar
Car Info: 2016 FXT
The motor is MINT, and has only 3k miles on it. The first 1.5k were break in miles and the other 1.5k has just been commuting, barely seeing boost if at all. Compression is perfect across all 4 cylinders.
The motor was built in Texas by my motor builder. Here are some specs, I think I am leaving a few out:
1. Wiseco Forged Pistons (100mm bore)
2. Hand Filed to fit Wiseco Rings
3. Polished and deburred STI Rods with ARP rod bolts installed
4. Deburred STI crank
5. Balanced Rotating assembly
6. Deburred block internally
7. Cometic Head gaskets
8. ARP head studs installed and triple torqued
9. Heads were cleaned, slightly polished, 5 angle valvejob performed, lashed at tip height to .010 intake/ .012 exhaust lash for high rpm( high horsepower usage) and all valves were lapped into their seats by hand
10. 2008 STI oil pump (blueprinted)
11. New O rings were utilized everywhere
12. Rod bolts were also triple torque cycled for proper torque retention
13. Micropolished Crankshaft
14. Gates Racing Timing Belt
15. ACL Race Bearings (Coated)
I was EXTREMELY cautious when breaking the motor in to make sure it was broken in perfectly. So this means you will be getting a built motor without having to go through the hassle of breaking it in knowing it was properly done so.
There is also an Aluminum Moroso Oil Pan on there right now that is as old as the motor which I can add to the cost of you want.
My asking price would be +/- 3500 depending on your mileage or if you want the oil pan etc etc.
This is just testing the waters so yea, let me know.
Old Jul 2, 2009 | 11:30 AM
NorCalDC5's Avatar
Car Info: 2016 FXT
Bump
Old Jul 2, 2009 | 11:33 AM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
Were the rods shot peened after polishing?
Old Jul 2, 2009 | 11:35 AM
NorCalDC5's Avatar
Car Info: 2016 FXT
I am not sure but I can ask my builder if you'd like.
Old Jul 2, 2009 | 11:46 AM
04caliwrx's Avatar
Don't trade for a 07 engine, they are crap. Go for a 06 engine.
Old Jul 2, 2009 | 11:50 AM
NorCalDC5's Avatar
Car Info: 2016 FXT
I know, my 07 blew with a perfect tune with only 10k miles on it
Old Jul 3, 2009 | 09:59 PM
NorCalDC5's Avatar
Car Info: 2016 FXT
Bump, I can even help install it for you if you want. I have taken out and installed 4 STi engines in the last year so I know what I'm doing.
Old Jul 6, 2009 | 01:50 PM
NorCalDC5's Avatar
Car Info: 2016 FXT
Bump
Old Jul 10, 2009 | 07:39 PM
NorCalDC5's Avatar
Car Info: 2016 FXT
bump
Old Jul 16, 2009 | 01:48 PM
NorCalDC5's Avatar
Car Info: 2016 FXT
bumpp
Old Jul 21, 2009 | 11:18 AM
iflycoach's Avatar
pm sent.
Old Jul 22, 2009 | 10:35 AM
NorCalDC5's Avatar
Car Info: 2016 FXT
bump, only 1 month before I go back to Texas
04caliwrx
May 8, 2016 06:14 PM
drakejesus231
Dec 15, 2011 11:00 AM
MJU1983
Cars For Sale
Jun 11, 2008 10:05 PM
bugeyehybrid
Cars For Sale
Nov 14, 2006 09:48 AM
gruppe-s
Engine and Drivetrain
Mar 25, 2006 01:59 PM
Top
