putting a turbo engine in a 91 legacy?
Old Sep 21, 2004 | 10:52 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
Originally Posted by jcool
what would it require me to change to put this in instead. exhaust pipe? any changes in the computor? or wiring ? anything ?
Yes.
Yes.
Yes.
and Yes.
If they have the engine, they might have the whole car.
To do it right, you'll need:
radiator
cross member
exhaust, complete
ecu
intake ducting
wiring harness(?)
and anything else I can't remember.
Old Sep 22, 2004 | 10:31 AM
DLC's Avatar
DLC
Car Info: 2000 Leg GT LTD
Check out my 1G Legacy BBS:
http://bbs.legacycentral.org
Best place for info on your car.
Old Oct 15, 2004 | 01:34 AM
subiekid's Avatar
Car Info: 95 Legacy ej22T - TEC 3
Also, stop by www.nasioc.com and read the FQA in the Conversions Forum. There is tons of info in that place.
Since your brothers car is OBD1 it will be easier. IRC there are only two wires that need to be added to the main harness, boost solenoid and something else.
You will need the turbo cross member, but you can use one from a WRX or STI. The fuel pump will need to be upgraded to the Turbo Legacy pump or an aftermarket unit. You might change the timing belt since the motor is going to be out.
Good Luck. I love my ej22T, I just need to get it running again.
mperalta
Feb 10, 2007 10:53 PM
lektr0nikz
May 5, 2004 07:31 PM
bluesubeguy
Oct 4, 2003 03:26 PM
washeretuesday
Sep 8, 2003 05:13 PM
bsams17
Jan 9, 2003 09:49 PM
