Is my 03 legacy motor same motor in ImprezaRS?
Old May 23, 2003 | 01:32 PM
AKSubie's Avatar
Depends on which year RS you are talking about. But regardless, aside from either being SOHC or DOHC engines (sorry, forgot which year they switched in the Impreza) the general consensus is that, yes MOST performance parts will work for either platform, differences being mainly the exhaust and intakes, seeing as the cars are of different sizes and therefore have slightly different routing. Internally though, for like the cams and the like, they should be identical. Might also want to try a search in the Natural aspirated forum and see if there are any known conflicts with the particular performance part you are wanting to get.
Old May 25, 2003 | 10:23 AM
ted1186's Avatar
Car Info: 2001 Legacy L
I've heard that there are problems with using an ECU designed for the RS in a Legacy, not positive though.
CaliSuby
Aug 13, 2012 12:07 PM
cloudpicker
May 10, 2006 11:56 PM
Double Phister
Jan 19, 2005 12:46 PM
delco-impreza
Jun 4, 2003 01:11 PM
