Cold weather starting problem 93LS
Old Nov 6, 2005 | 02:05 PM
54xenon148's Avatar
Car Info: 90,90,92,93 Subaru Legacys
Question Cold weather starting problem 93LS
My 93 LS won't start when air temp is 30F and is very hard to start below 50F. Also radiator fans come on immediately. Starts/runs fine in warm weather or on restarts if engine is still somewhat warm.
Classic problem is temp sensor. However Temp gage seems to reads correctly. Is this possible with a bad temp sensor ?
I understand the engine coolant temp sensor feeds both the dashboard temp gage and the engine computer which in turns controls the radiator fans,
I pulled coolant temp sensor.
Measured the resistance – 32F =4650 ohms, 65F = 2207, 200F = 440
Pulled coolant sensor from a different Legacy.
Measured the resistance – 32F =4450 ohms, 65F = 2510, 200F = 440
Bought a coolant sensor from AutoZone (only source open)
Measured the resistance – 32F =4360 ohms, 65F = 2468, 200F = 390
Basically no difference.
Chilton's manual (#8259 pg 2-34) spec lists: 212F = 26-29 ohms
This is 1/10th what I measure for all 3 sensors at 200F.
Is Chilton's spec wrong or do I have 3 bad sensors ?
How can I diagnose/fix this starting problem ?
Old Nov 6, 2005 | 02:36 PM
gosu's Avatar
Car Info: 121 CI of ... BOXER
what do you mean hard to start? hard cranking over? batteries hate the cold weather! make sure you have enough cca to start the starter in the cold
medicSTi
Mar 16, 2008 09:06 PM
rustokman
Sep 7, 2007 12:08 PM
fixmuflym
Dec 13, 2004 06:36 PM
Ditty77
Feb 4, 2004 03:41 PM
SnatchCritic
Jan 22, 2003 08:35 PM
