Help, 90's Legacy caught on fire
Old Jul 18, 2003 | 05:15 AM
go go go's Avatar
Car Info: GF8 ver6
wow..
when you say the car caught on fire, do you mean something was actually burning? or just small flame poped from the exaust pipe.?
If it is a fire ***** shooting out from the exhaust pipe, it means there is some problem in engine management I assume. Maybe misfiring.
Check spark plugs and spark plug wires to start with if you can.
I forgot if the early 90s model had direct ignition...I think it was direct ignition. It could be cracked ignition coil.
I don't think it's exhaust or cat, I'd take the car to dealer or to a mechanic who knows Subaru well.
Old Jul 18, 2003 | 06:41 AM
Subaruski42o's Avatar
Car Info: 98 RS
Ha ahhahaha the fire depo came to put your bumper out?????
I find that strangly ammusing
Old Jul 18, 2003 | 09:56 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
Hey, Adam, lighten up a tad.
I, for one, am laughing with you, not at you.
Yes, in the heat of things (no pun intended), it must of been scary, but now you can laugh about it.
Anyway, the problem you describe sounds like there is a lot of unburt fuel left in the exhaust gases.
As someone mentioned above, there is a serious fuel management problem.
I suspect the fuel injectors are running at, well, full throttle at idle conditions, spray excessive fuel into the motor. The fuel then puddles up in the exhaust pipe, waiting for a miss fire.
BOOM! Spark fires off during the exhaust stroke, and the flame travels down the exhaust pipe to the tailpipe, setting the bumper on fire.
Which, from my perspective, is funny as hell
DISCLAIMER: As I'm no longer a professional mechanic, don't take this rant as the Gospel.
Old Jul 19, 2003 | 10:34 AM
iClub Silver Vendor
Adam
Does the car run now?
Did you move/remove anything when you changed out the battery?
"Not wanting to idle" sounds like a vacuum leak, a big vacuum leak. Look at all the plastic ducting, making sure everything is in place & tight.
Look at the wiring harness. Are ther any exposed wires or loose connectors?
How well is the car being maintained?
Sounds like a trip to the local Scooby garage may be in order.
Old Jul 28, 2003 | 12:13 PM
eastbaysubaru's Avatar
Lightbulb
Check out this page and do the "Battery Dance". This will reset the ECU and then you can do some more thorough diagnostics.
http://www.surrealmirage.com/subaru/engine.html
-Brian
ej20_wagn
15
Mar 16, 2010 04:20 PM
Egan
Jun 9, 2006 05:48 PM
Kevinr
Oct 16, 2003 06:36 PM
DwithBoost
Sep 17, 2003 02:34 AM
IS2Scooby
Jun 1, 2003 07:09 PM
