Front suspention help!
Car Info: 1995 legacy L wagon
Hello every one I have been hanging out her reading up on stuff and now I need some help! It has come time to put Ball Joints, tierod ends, axles (2nd time), and maybe new stuts! any suggestions or hints on this would be helpful, ol I have a 1995 legacy L wagon awd auto.
thanks
mike Lomax
www.lomaxmotorsports.com
thanks
mike Lomax
KYB GR2 struts and maybe even new top mounts. Make sure you do all four at the same time though, to keep everything fresh, you won't regret it. As for axles, just getting a well done rebuild is important. I've done struts myself, but not attempted an axle or tie rod replacement. I'd suggest either the Haynes or Chilton manual for details.
I have checked on the Gr-2's and have heard that stock wrx springs on these would make a big diff, any ony know about this? I would like to up grade anything I can as I do this, any ideas on bushings? what is avalible for this car? Can I swap oem wrx parts? Im cool with doing the work but there is always a trick or two to help make things go along easyer, I have the haynes for this thing so everything is cool.
thanks
Mike
www.Lomaxmotorsports.com
thanks
Mike
