Fed up with my legacy, please help
Old Jan 21, 2005 | 09:02 PM
C_Noles's Avatar
Car Info: 01 Legacy GT
Question
Old Jan 22, 2005 | 01:01 PM
RU-X's Avatar
Car Info: 05 wrx
when was the last time that u brought it in for a tune up? and as for the battery thing it needs to be replaced every some odd years, its just how it is for cars...
but i'm guessing that because u have gas and a fresh battery and it won't start is due to a short some where in ur car thats just always drawing power, or you need a new engine harness... (i'm guessing a long shot on the harness... )
but yeah... GOOD LUCK!
Old Jan 22, 2005 | 01:39 PM
emyselfandi's Avatar
this is pretty good timing. My wife and I are visiting friends in Kenmore near ottowa and for the first time in its 10 year life it didn't start.... Its been -30 or so C at night the last few days.. thats pretty dam cold for any car. We used to fuel boost this am and it started after 20 seconds of cranking... I think its just water in the tank that gets frozen. Only suggestion i have is that when its warm our (like in June...) drop the tank and make sure there is 0 water in it... good luck TIm
Old Jan 30, 2005 | 11:08 PM
Jonathan's Avatar
Car Info: 1999 Subaru Legacy GT Limited - Quick Silver Metallic
you COULD try adding a can of "Dry gas" to your tank (when its above freezing), and then maybe another can every other tankfull. My understanding is this will absorb some of the moisture in the gas that has accumulated over the years from condensation.
I have never yet had a problem starting my Legacy although last week I had the origional (5 1/2 year old) battary replaced as it had been cranking rather slowly when cold.
Old Jan 31, 2005 | 08:48 AM
C_Noles's Avatar
Question
Old Feb 1, 2005 | 01:53 AM
Jonathan's Avatar
Originally Posted by C_Noles
Got another question though, how can you tell if your engine block heater works? should my temp guage be up higher when i start it?
Yes.
Some engine block heaters are designed to warm an engine up QUICKLY (~20 minutes), while with others your supposed to leave them plugged in overnight. I am not sure what type you have... but the radiator hoses should maybe feel slightly warm to touch... not full operating temperature... but warm enough that it doesnt take the engine long to reach that point.
Old Feb 1, 2005 | 02:01 AM
Jonathan's Avatar
Also... Another point... Please be aware that in really really cold weather battaries wont charge/re-charge properly. You have to drive around long enough that the heat from the engine warms the battary enough so that it will charge. If you do/did a lot of short trips when its really cold your battary could get run down really fast, and that MIGHT explain your eairler problems with it.
A special battary heater (sort of a jacket you place around the battary) could help to solve this problem. Not only will the battary charge quicker, but a warm battary will produce much more power than a cold one.
If you are willing to plug in your engine block heater, why not plug in a battary heater as well ?
Old Feb 2, 2005 | 10:54 AM
C_Noles's Avatar
Old Feb 5, 2005 | 01:08 PM
zunus's Avatar
Trickle chargers are the way to go. Battery blankets are good, so are battery pads(what I use). But trickle chargers are my favorite because if you kill your battery from trying to start your car you can let it sit for a day come back and try again.
If your car is totally 100% froze and you need to start it there are a few things you can do. Drain the oil, and replace with warm (room temperature) oil. Same applies to the antifreeze but I find the oil is easier to replace its still tough though because the oil is REALLY thick. But if you can get near an electrical outlet, get a small heater and put it under your engine for a few hours. Be careful not to get to close to electrical wires though or you will melt them. If your battery is the problem, pull it out and charge it indoors so it warms up. Then run out install it and start it.
dr3d1zzl3
Apr 5, 2004 08:59 PM
gpatmac
Mar 29, 2004 05:34 PM
sfwrx2
Nov 26, 2003 01:44 PM
Zoeb2s
Jun 2, 2003 11:46 PM
