97 Legacy Outback transmission rebuild options
Old Apr 23, 2006 | 09:52 AM
paulpas's Avatar
Car Info: 1997 Subaru Legacy Outback
What are available? I already have a phase II block w/ ported/polished DOHC rebuilt heads. Can I convert my 5-speed into a 6-speed or can I just change the 5th gear to a taller ratio for better highway cruising? Thoughts? My transmissions 3rd gear syncro is on its way out and the shift lever linkage in the transmission needs rebuilt, may as well get er done while the tranny's out. 229k miles.
Old May 19, 2006 | 12:07 PM
thesnowboarder's Avatar
Car Info: 1990 turbo miata
get the jdm RA's hella strong i dunno much about them thoe, but there super stong i know..
Old May 21, 2006 | 09:34 AM
DLC's Avatar
DLC
Car Info: 2000 Leg GT LTD
It's not possible to convert the 5MT to a 6MT, but it should be possible to change your top gear. It is possible to swap in a 6MT and corresponding rear differential, but I'm not certain how much taller 6th is than your current 5th.
http://gearboxtech.com can help you out...and don't be fooled, RA gears are not that strong...
blong401
Feb 13, 2007 09:06 PM
RedStage
Aug 9, 2006 07:53 PM
paulpas
May 2, 2006 07:58 PM
GODFATHER
Dec 1, 2005 01:28 PM
mkwired
Feb 10, 2003 09:35 AM
