Help taking apart 06 door panel
Old Jan 16, 2007 | 07:31 AM
BlowDro's Avatar
Car Info: 2006 WRX
hello, i need someone to help disasembling my door panels so i can re cover the fabric part. i have read in other thread that you have to "drill the rivets out" i have no idea what this means or how i would re-assemble the peices after. if someone could decribe it better like how many spots i need to drill out and what size drill bit i would need. the best would be pictures. thanks, max
Old Jan 20, 2007 | 08:37 AM
BlowDro's Avatar
Car Info: 2006 WRX
please
Old Jan 23, 2007 | 09:29 AM
june.rs's Avatar
Car Info: 07 pearl white wrx
lets see
if im not mistaken. door panels are hold on by clips. no drilling needed. if you look at your door handle there should be like a small opening enough to fit a poket screw driverin. pop that tab out. and then there is a regular screw driver and un-screw that out. there should be another screw where your arm rests. with the poket screw driver. take off the tab and you should see that screw. then wiggle that panel. try starting from the buttom. pull that panel. when you get to the window try pulling it up. let me know if you need more help. or if im wrong.
darkonion
May 23, 2007 12:47 AM
karis119
Dec 27, 2006 03:56 PM
337drew
Nov 21, 2004 02:52 PM
mweinst
Wanted
Apr 18, 2004 08:47 PM
04 WRX Subie
Jan 31, 2004 02:15 PM
